Page 6 of 61 FirstFirst ... 23456789101656 ... LastLast
Results 101 to 120 of 1208
    Feb 2010
    #101
    Quote Originally Posted by batang_raon14 View Post
    Tire pressure changes in the course of the trip hence the readings could be inaccurate. Pero usually dapat tumataas ang psi habang umaandar, this could be a rare case.
    Na-try niyo na ba pahanginan sa gabi to 32 psi, then kinaumagahan pagkagising i-check using a psi gauge? Mura lang naman sa ACE Hardware. :-)
    *batang raon. we will try to do that, and we will see what will be the outcome. Just keep monitoring your tire pressure for 2011 accent owners, the tires could be the problem since we are in a different enviroment.
    Jul 2010
    #102
    Quote Originally Posted by asb75 View Post
    Hi fellow tsikoter's, my wife find that our 2011 accent has a problem on tire pressure from day to next day basis. she noticed that the tires were always & almost were losing tire from visual looking at it, then she went to the vulcanizing shop to increase the tire pressure for all 4 wheels at 32 PSI from gauge reading. Then she notice again on the next day morning that tires were change almost losing pressure again. then she went gain to vulcanizing shop, to her surprise all of the wheels were not the same tire pressure. pressure reading from each tire are as follows, 27 PSI, 28 PSI, 27 PSI, 29 PSI. she already called Hyundai QA regarding about the problem. they said to bring the car on Saturday to check the problem. From what i've seen, since all of our units came from South Korea, might be the tires are not for tropical climate conditons, well keep you up to date about the outcome after the service. So try to keep a watch on your tires.
    boss di kaya maluluwag lang ung pito?
    Jul 2010
    #103
    ganyan din nangyari sa 2 tires ko, me singaw yan brader...doon sa sidewall...kailangan ng masinsin na tingin bago makita....
    sa awa naman pinalitan kasi under warranty pa....
    BTW, forte naman ang sa akin....
    Feb 2010
    #104
    Quote Originally Posted by xtian119 View Post
    could be? but there is a cap on the nozzle/pito so if air could escape it should not be more, and it affected all of the 4 tires with different tire pressure rating outcome. so its quite a mystery to us. tulad this morning daw bumaba na naman ang tire pressure ratin nang 4 na tires. we will see on saturday of what will be the outcome from the dealer since its still under the warranty period.
    Jan 2011
    #105
    Very unusual yan at four tires pa.... To have a more accurate reading, buy yourself a tire pressure as advised by batang_raon14 and check your tire pressure the next day on the same time and same traveled distance as yesterday when you took the reading.
    For my unit ala naman ako naexperience na ganito.
    Feb 2010
    #106
    Quote Originally Posted by desert fox View Post
    Kia forte naman sa iyo ang sumingaw na tires, siguro korean made tires din yan sir?
    Feb 2010
    #107
    Quote Originally Posted by andretti View Post
    we will send the unit at the dealers by saturday, it is stil under warranty period naman.
    #108
    Baka kapitbahay mo lang salarin nyan sir, inggit sa bago mo oto. hehehe.
    Feb 2010
    #109
    Quote Originally Posted by georgie35 View Post
    could be also?hehehe but i think not sir kasi naka lock ang gate nang garahe namin & secured location kami dahil nasa loob kami nang subdivision.
    Jul 2010
    #110
    In my experience lang kasi boss. Kahit may takip siya sisingaw pa din naman ung hangin. Nung bumili kasi ako ng mags bagong pito ung nilagay tapos ganun din hindi pantay pantay ang tire pressure kapag nag-check ako. Tapos naisipan ko lang na higpitan un pito maluluwag pala isa lang ung mahigpit. Ayun pare-parehas na sila ng tire pressure and hindi madalas nagbabawas
    Jun 2011
    #111
    got my accent today 1.4 a/t * hyundai balintawak medyo matipid naman sa gas dalawang guhit lang na consume ko 140 km ang tinakbo ko. first problem di nag lolock yung sa pasenger side sa harap nag pinto HAHA! ) ok lang alam ko naman na ganon mag yayare because of this thread e papaayos ko na lang sa first 1000 ko. suspension ok naman sya for me? ang ganda nya lumaro para saken. will update mo to this thread kung ano pa mga saket nang accent!
    Feb 2010
    #112
    nice to hear that sir, we will try that also, anyway we will see on staturday what will be the outcome from the dealer dahil naka warranty naman ito.
    Mar 2011
    #113
    mahina ba tlaga ang headlights ng accent? i have a medium dark v-kool full tint and mejo hirap makakita sa gabi and add to that umuulan pa. so what could it be... the tint? mahinang headlights? or umuulan kse? o sadyang malabo lang mata ko..
    Sep 2006
    #114
    dohc na po ba ung 1.4 engine??gamma engine ba ito?
    Jun 2011
    #115
    Quote Originally Posted by jayrb View Post
    for me mahina talaga kase nahihinaan din kasi ako.
    Mar 2011
    #116
    ALL OF THE ABOVE! LOL
    Ok naman headlights niya but the fact na meron kang medium dark tint eh medyo challenging nga yan pag gabi lalo na pag umuulan. Stick your head briefly outside the window at night and compare. You can tell na maliwanag ang headlights natin compared to looking out from the front windshield because of your medium tint. Try to go light on the tint.
    Sep 2008
    #117
    sir, malaking epekto po yung tint n'yo sa windshield... a medium-dark tint would probably reduce yung pumapasok na liwanag by about 20%...
    #118
    Actually mahina din talaga stock bulbs ng Hyundai. They use Osram ata. Tsaka nasa design din ng headlight reflector.
    Experience ko kasi sa Toyota Vios maliwanag kahit stock bulbs with 3M BC20 medium dark sa windshield. Sa Hiace naman sobrang liwanag pag walang tint nakaka-silaw kahit ikaw ang driver
    Mar 2011
    #119
    Quote Originally Posted by CooperS View Post
    So ano ba mas ok na gawin at economical? change my windshield tint? modify headlight? or pa laser ko na lang mata ko! pero seriously what mods can i do with my headlights ung abot kaya lang sana? Thanks!
    Jul 2010
    #120
    oo korean din(nexen)..i can not say low quality tires, siguro natyempuhan din lang...
    immagine ang init ng daan dito sa saudi ngayong summer dito,pang 2nd summer driving ko na siya dito......so far so good ang 4 tires ko...
2011 Hyundai Accent issues, problems in general
