Page 49 of 61 FirstFirst ... 3945464748495051525359 ... LastLast
Results 961 to 980 of 1208
    Oct 2009
    #961
    make sure that the problem is isolated para hindi ka magsisi sa pagbili.
    May 2012
    #962
    thanks po sa mga advice!
    ngayon ko lang na realize na dami pa lang dapat i-consider when buying a brand new car...
    Sep 2008
    #963
    Quote Originally Posted by ladydriver View Post
    yup dami talaga especially the cars reliability, durability, fuel consumption, low maintenance cost... and availability ng parts syempre kase mahirap mag antay ng ilang buwan para sa mga pyesa ng car mo... ang hirap titigan ng bagong car na di mo mapatakbo...
    #964
    VPower Nitro+ and Nitro+ Racing has drastically improved torque and power of the Accent 1.4 Gamma Engine. If I would benchmark it on percentage points, 15-20% improvement on the later.
    I suggest using this fuel as this is the compatible fuel for these high compression Gammas...
    Apr 2004
    #965
    Can somebody explain or describe how the engine knocking thing sounds like or how the power loss experience is?
    My 1.4A/T Accent is barely two weeks old with a little over 500kms on the odo. I've been very happy with it and have had no problems until I started reading on the issues raised in local forums such as these.
    Last Saturday, I drove my car up to Tagaytay and noticed that:
    1) While cruising at around 80kph on SLEX, whenever I would want to pass another vehicle, there are times when the engine takes long to respond to the accelerator pedal. It does not really feel like power loss in such a way that the engine drags down or the car slows down but rather more like the AT taking a while to respond.
    2) Coming from a full stop, when I slowly press on the accelerator, I hear a very very faint knock - something like light taps on a solid piece of wood. One that you would not hear of the radio is turned on or if you are engaged in a conversation.
    I'm worried now that I might be getting all psycho-somatic on my car. For one, I've been driving stick for most of my life, but the slushbox in a Pajero that I rarely drive seems to respond a little faster than the Accent.
    I took the car to the dealer earlier today and was told that I might have to leave the car overnight. I'm just thinking I might be trying to fix something that's not broken.
    Any insights on my dillema?
    #966
    have you asked your dealer kung updated na yan ng euro 2? if di pa, pa-update mo sakanila.. that will somehow eliminate the knock & low power issues
    also what fuel do you use? i'd suggest go for Shell VPower, Petron Blaze 100 or the least would be Petron XCS
    Apr 2004
    #967
    Thanks for the reply renzo_d10. From the time the car was delivered to me, I've gone through Shell and Petron. With Shell, I've tried Super Premium and V-Power Nitro+. Pag Petron naman, Blaze lang. Have not really paid attention as to what fuel the engine would start the mild knocking thing. It doesn't happen all the time anyways, but the last time I heard it, I was on a mix of half a tank's worth of Super Premium with 200 bucks of Petron Blaze.
    Is it safe to mix these fuels or am I concocting a recipe for disaster?
    Also, how long does it take to have the ECU reprogrammed? Kasi kung matatagalan din lang naman, isasabay ko na lang sa 1K PMS ko para isang hassle na lang.
    Thanks!
    Jul 2010
    #968
    may naka-experience na ba sa inyo from gear 1 to gear 2, kapag nag ni-release ko apak sa gas may tumutunog, then kapag inapakan ko ulit pareho din tunog, dati wala naman. hindi to engine knock na continues ang tunog.
    #969
    As much as possible avoid 93+ RON, most Accents kasi hindi hiyang sa 93+ RON fuel.
    Regarding mixing of fuels, no idea... because when I switch fuel, I take it to the point na at least 1/4 nalang natitira sa tank.
    Apr 2004
    #970
    Just an update - I've been loading up only on either Shell V-Power Nitro+ Racing (97) and Petron Blaze (100).
    Although not all the time, the knocking is still there. Usually between 1.5-2K RPM, right smack in the middle of where the needle drops everytime the A/T upshifts. I noticed it usually happens while the engine is still cold, and it does not manifest when I turn the A/C compressor off.
    I'm thinking if I should bring it already to the dealership or put it in along with the 1K PMS (odo is already at 750).
    Any suggestions?
    Jun 2010
    #971
    I am experiencing this slight rattling sound on my front left suspension which is more evident on uneven roads and bumps on the road. My initial suspect is probably the rack and pinion. Since i changed my stocks rims with 17", could this be the cause of the rattles? Does anyone else have this kind of problem?
    Aug 2011
    #972
    Quote Originally Posted by dinJ View Post
    Wow! Ganyan din akin sir sa front left suspension, at nasa 18k odometer. Tagadag nga Sir ang naririnig ko eh. Hinanap nila lahat ng reason bakit kumakalampag and they got to the conclusion na Shock mount Sir. After 3 weeks ng paghihintay sa replacement parts medyo meron parin kalampag, may problema din daw kse Tie Rod so will wait for the replacement parts to arrive. Nakakainis lang na nung ni-replace nila Shock Mounts eh nasira nila yung rubber ring sa tip ng shocks sa loob ng engine bay, can i have them replaced o OA na masyado?
    Don't buy a HyunDAY.
    Go for HONDA, FORD, TOYOTA, or even a MAZDA.
    Hyundai lahat ng line-up may sakit!
    #973
    Quote Originally Posted by mexophilia View Post
    Mali naman yata iyang statement na iyan, bro.
    There are a lot of satisfied Hyundai owners for Grand Starex, Sta. Fe, Tucson, Genesis, i10, Getz, et al....
    Right now, I own 2- to 4-year old(except for our Nissan) run-of-the-mill vehicles from Honda, Toyota, Nissan, and Hyundai... (You see,- no brand-loyalty for me....)
    And, in my honest opinion,- the best performer from among our lot, is our Hyundai vehicle.
    15.8K:dunno:
    Jun 2012
    #974
    [QUOTE=kimozi;1779194]sir yung sa akin 1.4M/T im averaging 6–7L/100km equivalent to about 14-17km/lit.(base to sa trip meter ko) mix driving highway/city (slex to shaw edsa). 1600 ODO[/QUO
    ung sa amin nagaaverage lng sya ng 6-7km/L.. grabe ang lakas sa gas. 1.4 na M/T pa un ah.. ung 500 pesos na gas na from alabang to makati back to alabng ubos ung 500.. 80-90kph lng takbo ko nun..
    Aug 2011
    #975
    15.8K:dunno:
    Good for you Sir.
    Pero based yan on statistical facts. Show me a line na at its first year walang major topak and I'll edit all posts containing Hyundai crap.
    And please understand the statement correctly, nakalagay jan na "lahat ng line-up may sakit", it doesn't say lahat sira. Meaning miski higher models hindi ka makakawala sa problema di gaya ng brands (who dedicated their time perfecting their cars) HONDA, NISSAN, TOYOTA, etc. na may mga topak din pero to their higher models very minor or wala. Sa Hyundai major issues palagi, at laging concerning pa sa engine nya.
    So warning sa aspiring future Hyundai buyers, weigh everything kung goods looks ba o sakit ng ulo.
    Aug 2011
    #976
    [quote=verdana;1947377]
    Quote Originally Posted by kimozi View Post
    Sir ganyan yung amin nung nag lolow power sya. Have it checked Sir. Isa yan sa mga sakit ng ulo na sinasabi ko. After my ECU replacement balik na sa 10-14km/lit. traffic from QC to BGC and back. Distance travelled everyday is 42 kms, so it's just 270 pesos on gas (I'm using V-Power +Nitro Racing).
    Aug 2011
    #977
    Quote Originally Posted by smarky13 View Post
    Sir yan na nga yung knocking. Load up lang on shell products, I recommend the higher octane ones mawawala yan.
    Aug 2011
    #978
    Quote Originally Posted by andro0120 View Post
    Any suggestions?
    Based on experience, kapag naubos mo na lahat ng remnants ng Petron mawawala yung knocking. Just load up on Shell products and i recommend the higher octane ones.
    May wokwok sound na prinoproduce yung compressor Sir, baka yun ang naririnig mo. The dealership changed my compressor so nawala yung wokwok sound na yan pero after a month of use bumalik din, so compressor bearing issue sya.
    Hope this helps. Marami pang susunod jan mga Sir lalu na sa mga suspension issues. Maganda pa ang suspension ng Vios Taxi na araw-araw laspag pero firm and stable, sa Hyundai Accent ilang months palang and of private use kumakalampag.
    Nov 2007
    #979
    Good for you Sir.
    Boss, I'm not a Hyundai Fanatic ha, and I owned two hyundais an i10 (sold later to get an accent) & an accent, and a honda city GM. Although, was able to dodge this knocking thing, pero to say nga mga All New models sa ibang brand walang problema.
    - Toyota's early D4D Engines (Innova, Fortuner) w/c is unluckily my dad owned one and sold the car when it is still around 6K mileage and lost over 250k (resale value is too low for the defective fort)
    - Early Civics' Engine Supports
    - Honda City GM (13k ODO Reading) /Honda Jazz GEs (around 6K ODO reading) thermostat. Belive me bro. My city GM & my sister's GE thermostats were replaced twice na. Condenser ko napalitan na rin, and feeling ko, condenser din problema ng GE ng sister ko.
    I'm with you in your opinion nga medyo mahina ang effort ni HARI to resolve this issue and it took them a year to find at least a good ECU setting..
    #980
    Okay,- objectively,- tama ang statement mo bro,- pero keep in mind na lahat ng line-up ng lahat ng vehicle manufacturers may sakit.... Puso mo...
    Kaya nga research research research. Walang impulse buying dahil lang gusto mo.
    That is why I usually buy a brand new vehicle after its first 2 years of introduction/release. And with this, I believe that I got the best from each vehicle class (kaya nga walang brand loyalty)....
    Pero kahit ganuon pa man,- may 'sakit' pa rin kahit papaano....
    15.9K:apple:
2011 Hyundai Accent issues, problems in general
