Page 36 of 86 FirstFirst ... 2632333435363738394046 ... LastLast
Results 701 to 720 of 1710
    Oct 2008
    #701
    sorry sir, I tried recording yesterday pero di lumabas sa phone. Try ko using a different recorder. masyadong mahina kasi yung tunog na yan sa unit ko.
    Quote Originally Posted by callmenadz View Post
    HAHAHAHA like your comment sir maxhedrum sige po ill wait the sounds para naman medyo ma enlighten ako sa sounds na yan
    Oct 2004
    #702
    Quote Originally Posted by maxhedrum View Post
    Mahirap tlaga irecord yang sound. Mahina kasi. Ako i used different phones for recording like from android to ip4 pero hindi makuha. Unless yung phone mo nasa loob ng engine bay recording hehehe. Hindi mo talaga madidinig yung tunog not unless hinahanap mo or alam mo.
    #703
    Quote Originally Posted by blurb View Post
    Ganito rin ang sabi sa akin ng SA ng Hyundai na nasa Southmall. May naka-display sila na Tucson dun sa may gitnang part ng Southmall so I took the opportunity to ask the SA about the knocking issue because i am considering getting a car in the near future.
    Anyway ang sabi ng SA, wala naman daw nagdadala sa kanila (hyundai las pinas) ng accent na may problema. Puro sa internet lang daw ang mga nagrereklamo.
    Sabi ko na nga ba sales talk lang yun eh. Sana sinabi na lang niya yung totoo.
    Brod, isa ako sa nagdala ng unit ko dun about that knocking issue. Ni reset ang ECU, nawala nga, even now, yung2nd gear lang ang problema ko, may delay ng 4 seconds bago humatak. tsaka recently, may whistle sound yung engine, parang yung sa Truck ng army ang tunog? may ganto rin ba kayo mag ka accent?
    May 2009
    #704
    Quote Originally Posted by georgie35 View Post
    Bro actually yung 4 seconds na delay sa second gear, yun na bale yung low power na tinatawag e, pansinin mo, pag nag humps ka tapos mabagal takbo mo syempre, minsan nahihirapan ituloy ng second gear yung andar mo after the humps, tutuloy naman after 4 seconds pero parang walang continuity yng acceleration mo kaya minsan gnagawa ko nag priprimera pa ako, pero pag diretso takbo ko sa highway, hindi naman siya nag lolowpower, usually lang talaga sa mga instance na kailangan mo magbagal tapos didiretso uli lumalabas yung problema. Yung sa truck ng army parang wala akong ganun na naririnig
    Oct 2004
    #705
    baka pinalitan ng isuzu diesel engine accent mo hehe.....just kidding. yung akin walang ganyang sound.
    Jan 2011
    #706
    Yung sa army trucks AFAIK kaya ganun yung tunog ng truck nila, ay dahil dun sa nakalagay sa tip ng muffler nila at hindi galing dun sa engine, pansin niyo ba may parang swing type cap yung dulo...
    May 2011
    #707
    Pano pala nirereset yung ECU? may kinakalas ba sa kotse
    Oct 2004
    #708
    Quote Originally Posted by jsfjr View Post
    Easiest way to reset ng ecu, tanggalin mo negative terminal ng battery, wait half hour or buong magdamag para sure. Tapos kabit uli yung negative. Voila!! Sa casa naman may kinakabit sila sa ecu na laptop or pc. Yung kabitan usually below the steering wheel or glove compartment. They can either reset or reprogram the ecu to new settings/parameters
    Mar 2011
    #709
    Sharing info might help others with knocking issue. My unit white 1.4 AT. Odo 4300km. Got it last march 30, Initially i thought i was not affected since knocking noise is very faint. After reading complaints here i checked and researched about it and apparently my unit has knocking issue too. Noise sounds like you have marbles inside the engine when feathering gas pedal with 1000 to 2000rpm range. Since casa's dont have solution yet i just tried to ignore it. Last week got a chance to joyride a bit at slex. Road was clear and got the chance to drive fast. Tried to keep it at 160kph as long as i could. After that run i noticed the engine knock issue is not manifesting anymore. So far up to now been observing the car closely so far so good. Maybe the others could try and hopefully that solves their engine knock issue too. By the way i used caltex silver during that highway run. Caltex gives better pull than shell unleaded although fuel consumption wise shell lasts longer.
    Oct 2004
    #710
    Quote Originally Posted by rbc.cerulean View Post
    Probably nag clear yung knocking kasi tanggal mga carbon deposit buildup when you ran your accent at that speed. But once you go back to city driving, there will again be a build up of the deposits maybe knocking will resume. I could be wrong though.
    Sir can you post your findings long term? Say after another thousand kms city driving if the knocking returns.
    #711
    Bro bratski pa-drive mo sa'kin yung Accent mo. Kahit city driving tanggal ang carbon deposit nyan :naughty2:
    Jun 2011
    #712
    good day mga ka accent ask ko lang yung accent ko kase kanina i started it then pinaginit ko lang muna yung makita then nun nirerebulosyonan ko na may usok na lumalabas sa tambutso ko and may basa na nilalabas yung tambutso ko kasama sa usok. ngaun ko lang na experience to x.x is this delikado? keke hope someone can answer my question TIA
    saka this pass few days parang lumakas ako sa gasolina last time 8.5/100 Liters lang lagi FC ko sa odometer ngaun 9.1-9.6 na di ko alam kung bumilis lang ako mag drive mas madiin umapak or what haist!
    Nov 2007
    #713
    I don't think carbon deposits ang culprit nitong engine knock. Kasi if carbon deposits, in my own opinion, althroughout RPM level, lalabas yong knock/ping. Ito, lalabas lang on mid 1500-2000RPM.
    And by the way, Im using petron XCS right now for testing purposes. I can't seem to find any knock/ping on the engine. Still testing though...
    After a full tank of XCS, I might dive in into a petron xtra unleaded fuel, para matest ng husto.
    May 2011
    #714
    WTF!!! its loosing power again
    Oct 2004
    #715
    Tried caltex for the first time a while ago. Lets see kung may improvement
    Aug 2008
    #716
    Sir, water coming out from the exhaust means that your engine is clean.. Hindi po masama yan..
    Jul 2011
    #717
    My first gas refill was with Shell but since my SA told me Total is ok too (there's an ELF logo on the dealer's plate by the way, and I know the company for quite a long time because my uncle works there for more than 10 years already), so I tried Total Unleaded... So far so good. No engine knock.
    Been refilling there for 3 times already.
    Nov 2007
    #718
    what fuel class does not use ethanol? Baka pwd rin nating subukan para macompare natin resulta ng combustion performance ng accent.
    Kasi initially CASAs would recommend to go to higher octane/RON fuels to temporarily solve the issue. It did ease the knocking on some units, but some didn't solved the issue at all.
    #719
    Blaze has no ethanol.
    Nov 2007
    #720
    ah ok sir. Correct me if I am wrong, pero sa pagkakaalam ko, some engines leave carbon deposits on high octane fuels due to fuel not burnt properly, however some high performance engines require high octane/RON ratings to avoid preignition. Baka lalong lumala ang knocking ng engine. But anyway it's worth a try.
    Well my unit is using XCS right now, and I don't seem to hear any pinging/knocking on the engine esp. when the engine is between 1500-2000RPM.
    I'll try using Petron Unleaded para masulit na ang testing for the benifit of everybody. Kasi I don't have any problems with any shell fuels from unleaded to v-power.
2011 Accent AT - Engine Knock!
