Page 82 of 160 FirstFirst ... 327278798081828384858692132 ... LastLast
Results 1,621 to 1,640 of 8077
    Oct 2004
    Kahit mag isa dapat naka on din yung rear aircon. Masisira siya kapag bihira buksan. I had a friend na nasira yung rear ac niya dahil most of the time naka off because siya lang lagi driver/passenger
    Posted via Tsikot Mobile App
    Plus it helps heaps with the circulation. Hindi laspag ang harap kasi sagot nung likod yung pagpapalamig nung, well, likod...
    No Signature
    Quote Originally Posted by GS LOVER View Post
    hi again mga bro, i would just like to share to all of you my experience with my GS, I was driving alone yesterday from Angeles city to Manila, since I was alone, hndi nakaON yon rare aircon and since long drive, i noticed later on that the aircon is not that cold, which was very uncommon, but when i decided to engage the rare aircon, everything goes back to normal. LESSON LEARNED: Engage the rare aircon every now and then even if you r alone for optimum aircon performance
    Looks like your front expansion valve is freezing i.e. covered with ice...
    Sep 2008
    The 110 KPH speed limiter is a new law in Korea for vehicles with capacity of more than 9 persons. All Hancars Grand Starex have been reprogrammed back to no speed limiter. We can reprogram your GS if they have speed limiter and you want it removed. The 160 KPH instrument cluster is deterrent to drivers who are speed demons, but you can watch your speed go all the way to 220KPH on our HUD. And we can also replace your cluster to 220 KPH.
    Sep 2008
    The Euro 5 engine has a trouble free EGR. If some of you are experiencing low power on Euro 5, it may be caused by other factors other than the EGR. Having regular PMS will be good for your GS. Guesswork or tsamba may not work on your GS, as it has a digitally managed system. A dedicated scanner is needed to talk to its system.
    Sep 2008
    Hancars offer 3 brands of oil for PMS: Castrol Semi, Zic Semi, and Hyundai Mobis DPF Premium Synthetic Oil. Surprisingly, most clients choose Castrol Semi. At Hancars, you have a choice.
    Under our local driving condition, it is not true that fully synthetic oil change should have 10,000 kms interval. That will kill your engine dead prematurely. You can do that with gasoline engine maybe, but never with diesel engines. You may do that in Europe, but not in the Philippines. At any rate, experts agree that if you want to use Fully Synthetic oil on a diesel engine, you must change the oil filter every 5K, and top off.
    Since our Hyundai Fully Synthetic oil is less than P2000 higher than our semis (for 6.5 liters), customers choose to have oil change.
    Sep 2008
    The ATF used on the GS are the fully synthetic ATF, SP-4. The GS Automatic Transmission is designed to work on fully synthetic ATF only.
    And yes, it is advisable to always turn on your rear A/C even at its lowest fan speed, and low cool. This will prolong the life of your A/C.
    If anyone of you sirs have technical questions, you may email me at: hancars*hotmail.com
    Thanks for your support, and pls give my kind regards to numbah5.
    Quote Originally Posted by Manxter View Post
    And around how much to replace the cluster? Stocks on hand, or on order?
    Sep 2008
    Sir, we always have stock on hand. If you want it, pls email me. or you may call me.
    We can also put speed limiter into the GS system, if anyone wants it.
    One of our neighbors' GS's front and rear lights were modified/augmented for/with LED lamps....
    WTF!- Nagmukhang perya ang itsura, sa laki ng ilaw ng sasakyan.... I'll take pictures if I have the chance,- kakatawa....
    “Familiarity breeds awe”
    23.5K:fart1:
    Apr 2012
    Mukhang Kumho ipapalit ko na tires. Or goodyear but 225/70
    Quote Originally Posted by dandang View Post
    Good day! Just had my stock tire replaced with also same brand hankook RA08 for Php5900 at banawe. The only thing different that i noticed was the original oem hankook is made in korea, but the new pair that i bought is made in CHINA. I hope it does not affect the quality of the tire.
    San sa banawe, which store?
    Apr 2008
    Its available at sonny ok store and mega motion. Sir ron 2008 din ba model ng GS nyo and is it from pitstop? Mine is from pitstop so i am assuming they got the gs cbu kaya siguro made in korea yung oem nya. The tires are exactly the same except for the made in korea and china part.
    Hoping i do not have the same bad experience as with sir ron. My stock tire was ok not sure about this china made tire. We'll see.
    3 GS namin, 09,10 and 13, all are CVX models, yung 2010 yata yung naka China na Hankook if I remember correctly, basta di yan napudpod, naoblong agad kaya napalitan agad.
    Apr 2012
    Looks like Kumho pinka maayos na Korean tire
    Quote Originally Posted by ronw123w124 View Post
    The same experience with our company GS bro.... Na oblong kaagad ang China made Hankook tyres... Three years lang......
    Anyone experienced a squeaky steering wheel?
    Low Beam:
    High Beam:
    Makikita mo na kung may nagbibihis sa building. Hahaha! Our high beams are actually pretty bad *$$.
    Low Beam:
    High Beam:
    Sir san nyo po pinagawa yung headlight nyo? Ever since hindi ako natuwa sa liwanag ng headlight ng GS ko tried using nightbreaker at philips, kalat yung buga nya. Iadjust ko maslalong naloko yung liwanag. Converted to HID yung low beam ok nung una now parang nagfafade yung lakas nya.
    Quote Originally Posted by jay2 View Post
    Oh, with due respect to you, Sir, as I didn't get to read your post prior to posting my previous reply, folks with bolt-on HIDs in the low beams need to take them out. Kalat na kalat yung buga, at dahil mataas ang GS natin, madaming nadadamay.
    For your reference, I'm using bolt-on Morimoto H1 bi-xenon projectors in the low beam housing. For their price, they're pretty good, and if you'd noticed, they have a clean cut off, meaning walang glare above the cut off. These projectors have a high beam as well, so when I flip the switch to high, I get to use the OEM high beam as well as the high beam of the projectors.
    Do consider getting these done. Not only will the light be more evenly spread, you won't be endangering other motorists.
2008 Hyundai Starex (Gen. 4)
