Sa akin 40 psi all around. Kahit nga 40psi na siya mukhang malambot parin. Siguro sa mga naka hvx pwedeng lower ng konti ang tire pressure dahil mas lower profile naman ang tires nila. Tagtag na kasi nun kung 42psi pa.
Try mo palitan nung smaller antenna tulad ng Tucson at Santa Fe. Kung pwede hehe.
parang standard naman yung thread ng connection ng antenna di ba? meron ako nakita sa concorde greenhills yata na rubber ducky antenna baka parehas ng thread. di ko pa na-remove yung sa gs ko pero yung sa sta fe looks like standard uhf/vhf rubber ducky yung thread e.
I just checked the tire pressure sticker near our driver door again. For HVX models its all equipted with 17" tires ang recomended ay 42 psi for each tire sa 215/65 R17
On the other hand naman for the CVX models na equipted with 16" tires. Ang recomend naman is 42 psi in front and 47 psi sa rear tires .. 215/70 R16 naman cya
So bottomline ay walang mas mababa sa recomendation ng hyundai na 42 psi per tires.
Dillema ko lang ngayon ay if i lower the psi baka mas mabilis mapudpud yung gulong kasi i did not follow the recomendation of hyundai
Yung first gen na starex nga e which we have , yung recomend lang ay 30 psi for each tires
I wonder why new starex have higher recomendations ng pressure sa gulong hehe
Mabigat din kasi ang Grand Starex.. he he. Tsaka yung tires parang high-pressure ata dapat. Mukhang tires ng truck eh
I follow the recommended tire pressure kasi it will make your tire's life longer and it will give you the best fuel economy. May tendency lang na medyo maging bumpy ride pero ok lang yan. He he. Sometimes I go over the recommended pressure, mga +1 or +2 PSi pa.![]()
I cut off all of the helical portion and retained practically just the base of the antenna....
13.8K:gotcha:
If the size of the screw is the same with the Tucson / Santa Fe OEM antennae, this could be another solution, he he..
This is the OEM antennae of the Tucson / Santa Fe:
There's the metal screw inside, just hope that it has the same size with the GS' long antennae screw.
If yes, then:
Tapos ok na, same antennae na kayo ng 2009-present local Grand Starex.![]()
Bro.SG,- malamang 2010(or very late 2009) to present GS... Kasi sa amin Oct2009 nabili, pero mahaba pa rin ang antenna... (Pero, baka nayari naman ako ng HARI...)
BTW,- nice shots....
13.8K:gotcha:
* ry tower, tama po yung conversion 42 psi talaga. You can check the booklet or yung sticker na nakadikit sa panel pag open mo ng driver side door mo
Alam ko din kahit na local na hyundai mataas din yung recomended na tire pressure e hehehe
Do you guys follow the recomendation or not?
Alam ko din kahit na local na new hyundai starex mataas din yung recomended na tire pressure e hehehe
Black HVX 2011 yung kay boybi. It's advisable to buy a Starex in Hancars, kahit Veloster pa. Si Juan591 muntik na mag local Gold yan binuyo ko lang sa Hancars kaya dun kumuha ng white HVX..
*juan591: bro ang pangit nung grille ha ha ha ha![]()
* sir cvt,
Gusto ko na rin paganahin yung built in gps ng hu ko, problem is hindi ko alam kung may antenna na siya, pero sigurdo ako wala pang gps software. I use garmin nuvi on my GS din kaso mas gusto ko iwas clutter ng wires kung direkta sa hu na ang gps
Sa mga naka 2010 model cvx/hvx units na 2 din touchscreen na ang hu. May napansin ba kayo na nakadikit sa windshield na black square na parang antenna? Katabi lang niya yung rear view mirror. At first iniisip ko antenna yun ng tv tuner. But kanina binuklat ko yung manual and yung drawing ng gps antenna resembles it. Hindi kaya gps antenna ito? Problem ko how to get the gps working, pag pinindot ko yung gps tab walang nangyayari.
Mahal pala nung Kenwood sir boybi hehe. We'll be taking a look at the units this weekend. Worth considering yung HARI GLS if all that needs changing are the shocks. Pwede naman magpa install ng better HU and monitors. Ang ayaw ko lang M/T lang sya.
Pitstop Motors ang sort of service center ng gray market units right? Kumusta naman ang service at warranty claims?
Sir Wh1stl3r, kung sa PITSTOP ka bumili, sa pistop lang talaga ang Service Center nya.. Unlike kay HANCARS, pede ka magpaservice sa accredited na HARI Service Centers nila like HARI Global City Hub, Alabang and GreenHills.
Tumawag na ako sa Global City, tinatanggap daw nila ang HANCARS unit. PMS man daw yan or Warranty claims pwedeng pede sa kanila. Kasi ang gagawin nila is sisingilin nila si HANCARS dun sa gagawin nila sa unit mo.
get the CVX from HANCARS, dka magkakamali...
* boybi,
Thanks for the clarification sir.
*wh1stl3r,
Service sa pitstop is generally ok, my 1k and 5k pms took around 30-45 mins to complete. Pwede mo pa silipin unit mo while its being serviced. So far (knock on wood) i haven't had a warranty claim yet. Pero back read ka a few pages, merong nahirapan sa warranty claim pero naayos din naman sa huli
Ipa bodykit nalang yan, same effect din. Although mahirap nga palitan yung grille.sabagay may point din si jiggs, ang gs ngayon parang ms narin sa dami hehe
