Results 7,301 to 7,310 of 8077
November 8th, 2017 12:01 AM #7301
- May 2005
- 273
November 10th, 2017 11:47 AM #7302Another update on my brakes problem.
I went to Goodgear in Pasay yesterday to have it inspected and if possible for them to do flushing.
They looked at it and found no problem with the line.
The chief mechanic, Arnel, advised me to go to another Hyundai casa for reset or reprogramming because it could really be the ABS module.
He also said that OBD scans may not really get the ABS module problem. The appropriate tool is the scan tool of Hyundai.
Goodgear does not have the ABS module but contacted another shop which sells it for Php 44k but without warranty because they will not install it. The said part is better installed by the casa because it needs brake bleeding with an instrument.
I then went to Hyundai Manila Bay but the service advisor said that most likely they will also conclude it to be the ABS module also and advised me to save the money for the re-scan (?) to buy the needed part. They do not accept parts bought from outside.
I am now at the point of deciding to buy the part from Hyundai and have it installed. Hyundai Las Pinas said they can give me 15% discount for the parts and P3500 for the labor. This will come to around P56k in all. It will just take 1 or 2 days to deliver the part.
Any last minute advise/s from this forum will surely be appreciated before I commit myself to this expense tomorrow.
November 10th, 2017 12:16 PM #7303
The thing is, casa “concludes” that the ABS module is the culprit for your dilemma. But, they are also not 100% sure that by pushing through with this procedure it will solve the problem.
Hindi mo rin masisi ang casa kasi this kind of problem is uncommon so they wont keep a spare abs module to swap out for tests like this.
Nagkataon lang na sa GS mo nangyari and you have to fork out a big amount to solve the issue.
Since you already had a second opinion with reputable shops and they all seem to pinpoint the ABS module, for your peace of mind go ahead and replace it.
Hintayin din natin sagot ng iba they might have other opinions about your case
- May 2005
- 273
November 10th, 2017 02:23 PM #7304Actually, fourtimes ko na kasi dinala sa Hyundai Las Pinas. Di ko lang nasabi dito earlier.
The first time, they recommended re-surfacing of the disk which I had them done.
The second time, they recommended replacement of suspension parts which I did not believe so I went to a Shell repair shop to have the suspension inspected and turned out that the suspension is solid. Pina-replace ko nalang ang brake pads sa Shell.
The third time, I think Hyundai did the reprogramming of the ABS which seem to work after a few trips but it returned. I'm saying ''seem'' because I was able to use the unit a few times only (Sundays) and short trips lang.
When I noticed that the front right side was not braking again, fourth time, they recommended replacement of the ABS module na.
During the 3rd and 4th time, it took them quite some time tinkering with my GS before concluding the replacement. They might have done the re-set/reprogram during these times but I'm not very sure because I'm not allowed at the service area all the time. BUt during the last check, I saw them use a wireless tablet to diagnose the problem. Just don't know kung paano naka-connect sa GS yung scanner nila na wireless - bluetooth, WIFI, etc???
November 10th, 2017 04:01 PM #7305
November 10th, 2017 04:14 PM #7306
the abs module is an electro-mechanical device. di naman nabubuksan yun. a hydraulic tube connects from the brake master and 4 hydraulic tubes connect to the wheel brake pistons. there is also a wire harness that connects it to the computer box. there is nothing there that you can "kalikot" and go wrong. it is a solenoid valve block. pretty solid. UNLESS the valves are the ones that go wrong.
my guess, and i am no newcommer to hydraulics, is that the particular valve going to the front right wheel brake is stuck closed. it happens. the thing with hydraulics is either there is pressure or not, or too low a flow to effect an action. there is no pressure because the valve is stuck closed.
and no they do not do repairs on those blocks nor replace valves. i would if i knew the part numbers and know where they sell them. but the casa? fat chance.Last edited by yebo; November 10th, 2017 at 04:24 PM.
- May 2005
- 273
November 10th, 2017 04:15 PM #7307You must have read my mind.
Yes, I plan to go there tomorrow for a fifth opinion before I commit myself to the P 56k expense at Hyundai Las Pinas. Fifth opinion kasi magiging pang-fifth ang Hyundai Sucat tomorrow.
So far, the opinions of the following sources are:
Hyundai Las Pinas - replace
Berima Diesel - ABS module not faulty
Goodgear chief mechanic - replace
Hyundai Manila Bay - replace
- Sep 2015
- 90
November 10th, 2017 04:51 PM #7308
- May 2005
- 273
November 10th, 2017 05:19 PM #7309
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
