Page 719 of 808 FirstFirst ... 619669709715716717718719720721722723729769 ... LastLast
Results 7,181 to 7,190 of 8077
    Nov 2007
    #7181
    Thanks sa replies. Mukhangdi ko kaya i-DIY ang paglagay ng usb outlet. Pagawa ko kana lang sa ACA
    Nov 2007
    #7182
    One important tip that i got from the FB group. Kung matigas buksan ang sliding doors, most likely dumidikit ang stock rubber stoppers that are on the top edge of the doors to the metal.
    Need to place new rubbers by using rubber stoppers for chairs from ace hardware, diy shop etc. 25 pesos lang.
    Madali na sya buksan. Hindi na mapuputol ang door handle. Mine broke off early this year.
    Here's what i bought from ace. Size 3/4. Need to trim a bit para flush fit over the old stopper
    #7183
    Tried to clean the paper cabin filters yesterday. I usually wack it on the wall to get rid of the dust. Integral na pala yung filter sa casing so i ended up breaking the plastic casing. Lol. Leason learned.
    Apr 2012
    #7184
    Quote Originally Posted by JJB View Post
    San banda ikakabit yan?
    Sent from my SM-J730G using Tapatalk
    Nov 2007
    #7185
    May existing rubber na sa top part ng sliding door. Trim mo lang yung new rubber before placing it flush on the old one
    Jul 2003
    #7186
    Yan mod ba is to prevent the door sticking? Ok naman oag bukas ng sliding pero maganda kung makatulong iton mod ma preserve yun mechanism.
    Ang hina palan ng foglights. 27watts parang Drl.
    #7187
    Quote Originally Posted by kurt View Post
    Yes they are, and their position is very low to make an impact. So, basically, just position lights.
    That is why I just changed them to yellow color...
    The same with my high beam headlights....
    Jul 2003
    #7188
    Ok yun low beam after palitan ko to osram NB unltd. Yun sa ace binili ko na 110% kahit alam ko may sellers na ng 130%.
    Sa hi beam, hindi ko ma adjust independent ng lows kahit yun lower screw pihit ko.
    Sa fogs h27-880 ang tama, yun straight, nasayang binili ko na elevo h27-881 pa L sya.
    Na itaas ko aim pero malabo talaga. May knob yun adjuster pwde dukot pala. 2 screw clips open na yun underside cover.
    #7189
    you changed your hi beam headlights to yellow??
    #7190
    Yes bro. Low beam remains white Philips Xtreme Power and high beam which I seldom use is yellow and the combination gives a very good contrast on the road....
2008 Hyundai Starex (Gen. 4)
