Page 662 of 808 FirstFirst ... 562612652658659660661662663664665666672712762 ... LastLast
Results 6,611 to 6,620 of 8077
    Nov 2007
    #6611
    Yeah that's what i used when i changed mine
    Sent from my LG-H818 using Tapatalk
    Thanks again. Time to look for a shop with dialysis near Katipunan.
    #6612
    Yikes! Papalitan na po! [emoji4]
    Btw, anyone encounter problems with their front power locks (not locking) and door switches (not registering that doors are closed)?
    Sent from my Motorola Startac
    Driver's door bro.... kapag nababad sa init na araw, ayaw mag lock o bumukas.... Else, okay naman, and so i always double check...
    #6613
    Quote Originally Posted by JJB View Post
    What atf fluid ginamit mo? Tama ba Zic atf SP-IV ang equivalent ng red-1? Yung castrol multi vehicle is SP-III only
    Sent from my LG
    Thanks for confirming bro.
    I'll start looking and stocking up on the zic atf sp4 as our unit is over 35kkm now. I'll check if our tci at uses the same atf as that of the vgt at
    Apr 2012
    #6614
    I'll start looking and stocking up on the zic atf sp4 as our unit is over 35kkm now. I'll check if our tci at used the same as that of the vgt at
    I think yours is sp3 compatible! I'll check sa manual later
    #6615
    Just a thought. Dialysis coz di daw natatanggal yung nasa torque converter.
    What if you did the regular ATF change but at a shorter interval, di kaya maghahalo na din yun at maisasama sa pag-drain?
    #6616
    Re door switch, had to have the driver's door and passenger sliding door replaced. Baka rear door na sunod.
    Front door locks had to be repaired this year. Ayaw maglock/unlock with the remote. Diagnosis nung electrician ko is ubos na carbon nung motor. When he got through with it, buhay na ulit pareho. Although, di na umiilaw yung signal light to acknowledge the doors are locked via keyless.
    Strange that I haven't had these problems with my Jap cars previously.
    #6617
    pwede naman bossing drain, fill up, run for few kilometers, drain, fill up. the end result will be a much cleaner atf compared to just a single drain and fill. pwede na diy.
    #6618
    I know, medyo tedious din nga naman especially if always on the go.
    Yung dialysis kasi takes up mga twice or thrice the amount of a drain and refill kaya medyo masakit. so if one had the time and chance, tyagaan naman with shorter intervals.
    #6619
    That is actually a novel idea, bro....
    I just have a couple of questions,- what's the approx volume of the ATF in the torque converter? what is the approx volume of ATF overall? With this, we can compute for the purity of the ATF after x drain/refill, assuming the ATF becomes homogeneous after X Kms of driving....
    _/_/_/
    30.3K _/_/_/_/_/_/_/_/_/_/
    #6620
    Hehehe! Now that's the tricky part to this theory. How long before it'll actually work...
2008 Hyundai Starex (Gen. 4)
