Originally Posted by
yebo
^ i had a similar problem with a santa fe, the serpentine belt was noisy. Turned out the culprit was a busted pulley bearing, and this in turn put stress on all the pulleys including the alternator and air con compressor clutch bearing. Recommended ng mechanic (not hyundai, their solution when i went to the hyundai casa was to replace everything -belts, pulleys, tensioner and alternator at a cost of 120k++) was to replace all pulleys and replace all bearings on alternator and air con compressor, approximate cost was 15k. Di ko na din pinagawa as i sold it na lang.
pero that seems to be the solution to that problem once the serpentine belt starts to make noise. The bearings already are starting to seize and if you do not replace them it will damage the alternator and air con compressor bearings. Kaya mas maganda pa din yung separate belt for the compressor and alternator, di nagkakadamayan pag may masira na isa lang.
