Page 160 of 160 FirstFirst ... 60110150156157158159160
Results 3,181 to 3,200 of 8077
    Jan 2008
    Oo nga. Pero baka abutin ako ng siyam-siyam bro.😂😉
    Hard starting ngayon ang GS namin.. Like it takes 2 to 3 cycles in the first click bago mag start.. Fully-charged ang battery.... Mukhang hindi properly napa prime ang krudo. Could this be due to the fuel filter?
    After driving and you stop the engine, and then you start after 10+ minutes, first cycle in the first click, start kaagad...
    Nawala ba ang hard starting sa iyo bro nuong nagpalit ka ng fuel filter?
    Sent from my Nexus 7 using Tapatalk
    pag CRDi ang makina alam ko may electric fuel pump yan to prime the system bago mag start.. sa 2008 kia carens kasi wala na yung manual hand pump to prime the fuel system, may madidinig ka lang na electric pump running for a few seconds then start ka na
    Oo nga. Pero baka abutin ako ng siyam-siyam bro.����
    My battery was almost dead, i was needing to charge it every other day. One time i was about to enter the garage, i shut down, opened the garage door, then it cranked very slowly when i tried to start it. Luckily i had an extension in the garage so i connected the charger and was able to start it after just 10 minutes charging. I went to our neighborhood motolite but the price he was asking was beyond the contents of my wallet that day. I had panasonic delivered and that solved my starting problems.
    The fuel filter i replaced because it was time to do so, 20k km odo reading already. It was not the cause of the hard starting.
    Are you sure there is no water? Maybe you had not driven much during the lockdown and there is a lot of condensation in your tank.Try priming the system. Open mo lang yung bleed valve under the filter and activate the hand pump. If you can catch the discharge do so so that you can see if there is any water. Any signs of dirty fuel will also show in the discharge. If you find plenty of water you may have to drain the fuel tank before you change the fuel filter.
    If you think there is air then it is the top bleed valve you will need to open to prime the filter. Crack open the valve, (about 1/4 - 1/2 turn) activate the hand pump and see if air bubbles come out.
    Sana may update si bro.mike18.... 😑
    sir ok na GS ko, stuck up yung EGR valve, hindi maayos yung pagkagawa nung nagpalinis ako ng egr at intercooler, pati intercooler hose pilipit din, nag assume ako na ok yung EGR kasi bagong linis lang, di ko alam na palpak yung gawa, mabuti magaling yung natawag ko na mechanic, pag start pa lang alam na agad yung problema.
    Quote Originally Posted by mike18 View Post
    Good to know bro that your troubles are behind you...
2008 Hyundai Starex (Gen. 4)
