Page 157 of 160 FirstFirst ... 57107147153154155156157158159160 LastLast
Results 3,121 to 3,140 of 8077
    Aug 2012
    You can also have the EGR, intake manifold checked. If they’re clean the previous owner most probably had it cleaned before.
    Actually i scheduled cleaning for this weekend, dint know how to check if its clean or not. Not really familiar with these things. Hope the guys doesnt proceed if ita not necessary.
    Sent from my VTR-L29 using Tapatalk
    QC ako e dito din lang ako kay powertorc motors pag atf dialysis. All others kaya ng gas stations.
    Btw, part lahat yan ng 40k km pm. So review the pm records baka naman nagawa na nung 40k km service. But of course for your peace of mind di naman masamang gawin ulit lalo na malapit na din 60k km service ng gs mo.
    Aug 2012
    You have a point sir, might as well have it done for peace of mind.
    Sir for below, what do i need to buy if i already have a mechanic to do it?
    2. Flush brakes
    4. Flush cooling system
    5. Change power steering oil
    For atf, needed talaga sir yung dialysis method?
    Thanks for your inputs sir, really appreciate it!
    Drain and refill lang for atf at every 40k kms. Thats fine. Leave dialysis for ultra long atf changes.
    Aug 2012
    Quote Originally Posted by istan View Post
    Thanks sir! Is Mag1 a good atf brand? If not, what do you recomend? Thanks!
    Apr 2012
    Quote Originally Posted by boogie18 View Post
    Find zic sp4 sellers on fb. Yan gamit ng karamihan na kakilala ko na naka GS including me hehe
    Sent from my SM-J730G using Tapatalk
    Meron hyundai fs oil sa Lazada, Hyundai XTeer Diesel Ultra C3 5W-30 fully synthetic oil for P1950 for 6 liters or 7 liters + oil filter for P2670. That is only P325 per liter, very reasonable for a fs oem oil.
    https://s.lazada.com.ph/s.RC5m
    https://s.lazada.com.ph/s.RC5n
    Aug 2012
    Nice, have you tried using this sir yebo? Was planning to use motul but this isnhalf the price!
    Safe to say, atf, buy from casa or consult ur manual. Ok lang expensive fluid, long change intervals naman.
    And better safe than sorry.
    Consult your manual what are the required fuids. Pero sa brake dot3 or dot4 lang yan. Higit 1 liter magagamit for proper flushing so bili ka 1 liter plus 250ml. Sa power steering same fluid as atf. 1 liter din magagamit dyan sa power steering. Yung coolant lang ang alam ko na may particular coolant type ang hyundai. Meron nyan sa olx o shopee.
    Sa transmission check the color. Pag dark redish brown na pa-dialysis mo. Pag red pa naman ok lang drain and fill.
    Only way to check the egr unfortunately is to dismantle and have a look.
    To satisfy my curiosity i checked under our GS last night. May DPF nga. Its approximately below the front passenger seat. Looks like a catalytic converter na pang gas engines.
    Aug 2012
    Hi guys, do you know where i can get the third brake light sa spoiler changed? Thanks!
    Apr 2012
    OT lang.
    Pa byahe ako to Caticlan via Batangas Pier.
    Okay na ba rfid sa star toll?
    OT lang.
    That is why they're advertising bro..
    But I have not tried....
    Hanggang doon lang ako sa extension of SLEX after Calamba....
    Apr 2012
    Ok bro will just ask the teller. Thank you
    OT lang.
    Yes Chief, OK yung RFID sa Star tollway. Used mine before Holyweek and no problem whatsoever.
    Quote Originally Posted by jvnj View Post
    Bro.,- kahit na doon sa mga exits katulad ng Tanauan? May fixture na for reading RFIDs? (ang pangit kasi ng booth doon nuong dumaan kami a few months ago,- parang shack lang)....
    Sep 2014
    Good day guys, i recently found out my 2015 CVX GS has leaking injectors because the sides of the injectors has fluid, although there seems to be no loss of power, i was thinking the seals are the culprit,....anyway anybody would recomemend which one is better, ishimoto or central diesel?
    Sent from my SM-G965F using Tapatalk
    Quote Originally Posted by mitchT View Post
    As in basa ng diesel? Madami? Baka naman may maluwag lang na injector tubing nut at kaya mo na higpitan lang. There will be no loss of power as long as the pressure is still there. The injector will fail to deliver fuel to the cylinder only if the fuel pressure is loss, like when if the fuel line is loosely connected. Pag small leak lang from a fuel line nut that is very slightly loose di mo mapapansin lost of power.
    Sep 2014
    I tried tightening the bolts and cleaned them to see if it will leak again in a few days, i couldnt send the pictures, it wont upload
2008 Hyundai Starex (Gen. 4)
