Page 135 of 160 FirstFirst ... 3585125131132133134135136137138139145 ... LastLast
Results 2,681 to 2,700 of 8077
    baka mag fail yun thermostat and only used distilled water... sana meron sila fire extinguisher... i have one and i check the good/bad gauge once in a while...
    Apr 2012
    Ano yun? Di kinaya ng distilled water na? I know a lot of old drivers still use distilled Water in their old rides
    Sent from my SM-J730G using Tapatalk
    these old drivers were brought up, with cast iron engines. these old blocks (blokes? ha ha) don't really need anti-rust that much.
    iba boiling point..
    Jun 2012
    Bigla na lang nasira ang lifter damper ba ang tawag dun? Yung nagbubuhat ng liftgate. Hindi daw warranty ng hancars yun. Dapat warranty yun di ba? Anyway, buti di naman masyado mahal. 680 per piece lang. Nagtataka lang ako l300 namin 16 yrs na stock pa rin gamit
    Sent from my SM-A9000 using Tapatalk
    Quote Originally Posted by dct View Post
    ...korean...?
    Deny happy sila bro. I think engine/tranny lang sila. But HARI is not much better. Have you watched "You Don't Mess with the Zohan"? Trying to claim warranty there is like doing it at the Israeli electronics store.
    Yung 680 price sa labas yun or sa kanila?
    Jun 2012
    ...korean...?
    Maybe? Or mabigat lang talaga ang pinto? I don't know. Mabigat sya nung sira ang dampers, pwede ako magpalaki ng biceps. Haha
    Sa labas na. I bought it at vgt store sa banawe.
    Sabagay. Kahit siguro hari di naman tatanggapin yun. Haha
    Apr 2012
    Kupal yang Hancars sa warranty.
    Jun 2012
    Pero nakaclaim na ko dati sa pang ilalim. Ball joint ata yun
    Nov 2007
    Sa lumang fort, madali rin masira yang part na yan. Tawag nila is door stay
    Trying to claim warranty from Hyundai
    Bigat nga ng tailgate ng GS. Thinking of getting an electronic tailgate opener by Growl Audio.
    33,200 cash pwede daw installment at 3,400 per month.
    Encountered a problem with my LED headlight bulb upgrade. Turns out for Hyundai Cars, kelangan ng H7 adaptor. Ipapa-ship pa from the supplier in HK.
    So natuwa ako sa LED Bulbs and decided to upgrade my dome & map lights from a friend who is a seller. Maganda naman ang resulta mas maliwanag siya than the stock incandescent bulbs. Natuwa pa uli ako so nag-order ako sa Lazada naman ng bulbs for tail lights kasi walang available dun sa kaibigan ko. I was disappointed sa outcome. Mas maliwanag pa din ang stock. Nag-search ako sa Google tungkol sa LED bulbs not being "bright enough", turns out the cheap LED bulbs you can buy online or at stores will never be good enough for tail lights, reverse lights & signal lights. There are good ones but expensive. Around 45-50$ per bulb. And even those are only 20% brighter. So in conclusion, not worth it. I will stick to the stock incandescent bulbs for now.
    Aug 2011
    Hello ulit.
    Nagpakarga ako sa unioil and napansin ko lang may banner sila na all their fuels daw ay euro 5 na.
    Ok lang ba na yun ang ikarga sa euro 4 na makina? Yan ay kung talagan euro 5 ang fuels nila ha.
    Thanks in advance
    Quote Originally Posted by spat View Post
    Hello ulit.
    Thanks in advance
    ok lang magkarga ng better rated fuel. so kahit euro 6 yan ok lang. a lot of euro 2 vehicles (up to 2012/13/14 starex even) have been using euro 4 e. pati nga old school diesels wala naman bad effect sa fuel system.
    ang masama e yung euro none ikakarga mo sa euro 4, masasakal yung exhaust sa dami ng sulfur soot at bubuga yan ng sandamukal na usok pag nagregenerate ang dpf.
    Edit I asked this question na pala before...
    Sorry sa thread bump hehe
    Aug 2011
    Thank you sa pagsagot
    Bros,- sa mga naka TCI - 4AT na tranny.
    Ano ang spec ng ATF ang ginamit ninyo?
    At ilang litro ng ATF ang nagamit ninyo para sa inyong dialysis? TIA.
    My ride is nearing 40KKm and so, this is imminent.
    Thanks again, bros.
    Oct 2017
    Mga sir. Ung headlight ko sa right side "pukpuk" system para umilaw. Just found out na ang ikinabit ng local shop dito is 100w bulb and ung socket nya is good for 55W lang. Ayun natunaw siya.
    Anyway, wala kasi daw sila nun sa good gear.
    Any recommended stores na makakabili ng headlight socket na yun?
    Tia mga sir.
2008 Hyundai Starex (Gen. 4)
