Page 116 of 160 FirstFirst ... 1666106112113114115116117118119120126 ... LastLast
Results 2,301 to 2,320 of 8077
    i would not recommend using wd40 or any oil on the rubber gasket of the doors. Oil can cause the rubber to deteriorate.
    On the sliding door rails and also on ordinary door hinges i suggest silicone spray lubricant. On the door rubber gaskets just regular cleaning with soap and water. Clean both the rubber gaskets and the area where the gasket seals.
    I just wet it, or wipe it with a wet cloth...
    The stickiness wears out after a while....
    29.9K _/_/_/_/_/_/_/_/_/_/
    Aug 2012
    Most people think of WD40 as the usual WD40 Multi-purpose Lubricant. WD40 has multiple products for different materials. They have Contact Cleaner, Engine Degreaser, Silicone Lubricant, White Lithium Grease, etc.
    Sent from my D5833 using Tapatalk
    Jul 2016
    Quote Originally Posted by red_one View Post
    Have you tried sir the WD40 Dry Lube? Effective ba?
    Aug 2012
    Quote Originally Posted by Tm.Lakas View Post
    Hindi ko pa nasubukan. 3 pa lang ang meron ako. WD40 Silicone Lubricant, WD40 White Lithium Grease at WD40 Multi-purpose Lubricant.
    Nov 2007
    Anong alarm ang pwede i-upgrade sa units natin? Di na gumagana ang remote din kse.
    Isa pa napansin ko na halos lahat ng door sensor ay sira na. Interior lights don't light up anymore pag open ng sliding doors and passenger door.
    Aug 2003
    Quote Originally Posted by JJB View Post
    Ito gamit ko, Viper 350HV:
    Pero nung 2010 ko pa nabili yan sa Araneta Car Accessories for P4,500. Ok naman siya.
    Aug 2011
    Mga boss,
    Paano magcheck ng atf? Parang wala akong makitang dipstick (sa ibang sasakyan meron)
    Quote Originally Posted by spat View Post
    Mga boss,
    walang dipstick ang tranny ng gs, sealed type ang tranny. time na ba for atf change (40,000km)? make sure dialysis method ang pag change ng atf para ma-flush ang torque converter.
    Aug 2011
    Ah ok. Thank you. Hindi pa naman. Wala pang 10000 nagamit ko. Nakaugalian lang magcheck from time to time. Yung sa engine oil lang kasi nakita kong dip stick. Ty ulit
    Nov 2007
    Quote Originally Posted by Automahn View Post
    Thanks! Time to revisit Viper. nung 90's pa ako nakagamit ng viper sa civic esi ko. hahaha
    Tumutunog pa ba yan?
    Viper Arm!!! Viper Disarm!!!
    Aug 2003
    "Protected by Viper, stand back!" :
    Di sir, walang voice warning ang Viper 350HV. Yung higher models ang may nagsasalita. Entry level lang yung sa kin.
    Di sir, walang voice warning ang Viper 350HV. Yung higher models ang may [SUB[/SUB]nagsasalita. Entry level lang yung sa kin.
    Oops. Nagkakabukingan na ng edad😄
    ^^^ Basta iyong sa amin, OEM central lock and alarm...
    Yuy, mahal ang nagsasalita ng ganyan noon.....
    Dec 2007
    Mga sir, question lang po..
    Reasonable ba na gumastos ng almost 100k parts and labor para sa clutch component ng grand starex 2010 model crdi?
    Need recommendations and suggestions kung saan shop magaling gumawa outside casa. Thanks in advance.
    Nov 2007
    Guys, ano kaya problem if driving sa curved road and the steering has resistance? Parang kumakabig sa other way. TIA
    when you said "curved road" are you referring to the slant of the road surface? normal yun parang nahuhulog o kumakabig papunta sa lower part ng road. pero kung kumakabig kahit na level ang surface (like pag nasa parking lot ka ng mall) e wheel alignment ang problem mo.
    Nov 2007
    Happens when turning slightly sa long curved but even road. Let's say you're turning the wheel to the right and kumakabig sya to the left. Will have wheel alignment done. Thanks!!
    Also, how much atf do we need for a drain and fill ng vgt Starex? Will have the atf changed at 80k kms instead of manual stating 200k kms iirc
    had mine done before i sold it using dialysis method. total 15 liters. di pwede drain and fill lang di makukuha yung nasa loob ng torque converter. it took 10 liters before the oil draining out started to clear and was perfectly clean after 14 liters. The extra 1 liter is for insurance.
2008 Hyundai Starex (Gen. 4)
