add ka lang ng water.
Sent from my SM-G920F using Tapatalk
^^ agree that either fuel filter is clogged and needs replacement or EGR needs cleaning. Happened to me twice already. First was dirty fuel filter then second time was dirty EGR
I'm getting an alarming amount of brake dust from the front brake pads (supposedly OEM) I got from Fronte. This is definitely not OEM. Baka walang 5TKm ubos ito, ang bilis magpulbos. Butt gyro estimates braking to be 10-15% weaker.
Yung shocks naman from Seiring ang tigas under compression. Also definitely not OEM despite their claim. I waited for the suspension to settle, but after 1TKm ganun pa din sya.
Anyone with a workshop manual for the GS? Our unit is an HVX. Baka merong magkakaibang part number for these parts? Or talagang naisahan lang ako?
Bro,- OEM brake pads produce a lot of brake dust.... For those who bought brand new,- this is the regular thing with them.
Mine was good for about 20KKm, regular driving, before I replaced them... My ride is automatic.
I cannot comment on the others. I have not replaced my shocks yet.
29.2K _/_/_/_/_/_/_/_/_/_/
2010 model matic 80k sa odo.pansin ko lang na hirap humatak maski sa hway yung van namin pag oovertake,parang wala na yung dating pagapak m sa accelerator hatak kaagad.ano kaya problem nito?
sir nawalan din dati power GS ko matic 09, dami kelangan check, atf,fuel filter etc,, pro sakin ang prob pala eh turbo actuator not working sira na diapram, kaya check mo sir ,ganito silipin mo ang turbo actuator na parang turumpo cya sir sa ibabaw ng turbo,pa start mo dapat makita mo na itutulak ng actuator ang lever pababa hangang stopper niya, tapos pa rev mo paulit ulit dapat nag tataas baba cya,,pag hinde o mahina pa check mo na sa expert ang actuator,baka may butas na diapram,kung meron ka hand vacuum pede yun pang test sa actuator,,pati turbo solinoid pa check mo rin,, sana makatulong,,
Who practice 10k kms change pil here?
Sent from my LG-H818 using Tapatalk
What's the solution for sticky sliding door?
i would not recommend using wd40 or any oil on the rubber gasket of the doors. Oil can cause the rubber to deteriorate.
On the sliding door rails and also on ordinary door hinges i suggest silicone spray lubricant. On the door rubber gaskets just regular cleaning with soap and water. Clean both the rubber gaskets and the area where the gasket seals.
