Page 720 of 808 FirstFirst ... 620670710716717718719720721722723724730770 ... LastLast
Results 7,191 to 7,200 of 8077
    #7191
    Yes bro. Low beam remains white Philips Xtreme Power and high beam which I seldom use is yellow and the combination gives a very good contrast on the road....
    i tried that combo, years ago.
    na-hilo ako...!
    #7192
    na-hilo ako...!
    I guess maswerte lang ako bro dahil it suited me.
    Great visibility when it is raining and you're on your own as the yellow-white combination "penetrates" the rain drops....
    #7193
    good contrast for near objects, good penetration in fog or rain, and less glare than any other color. i've seen a bmw with the same combination, yellow fogs and high beams, white low beams. this was in daytime ha, naka-off ang lights pero kita na yellow ang bulbs kasi kita dun sa reflector yung color yellow ng bulbs.
    napaisip tuloy ako. picture naman ng hl mo sir cvt para makita kung kulay yellow din yung reflectors pag daytime.
    #7194
    Quote Originally Posted by JJB View Post
    One important tip that i got from the FB group. Kung matigas buksan ang sliding doors, most likely dumidikit ang stock rubber stoppers that are on the top edge of the doors to the metal.
    Need to place new rubbers by using rubber stoppers for chairs from ace hardware, diy shop etc. 25 pesos lang.
    Madali na sya buksan. Hindi na mapuputol ang door handle. Mine broke off early this year.
    Here's what i bought from ace. Size 3/4. Need to trim a bit para flush fit over the old stopper
    Could you take a picture of this sa actual door sir?
    Thanks!
    Nov 2007
    #7195
    Here you go...
    #7196
    Here you go...
    Big thanks!
    Off to the hardware store tomorrow!
    #7197
    Kitang yellow ang bulbs ng high beam, but will take a pic bro, asap....
    #7198
    Thanks for sharing bro.
    Maybe I'll try this too.
    We usually "unclip" both sliding doors using the handle, and pull it through the side body of the sliding door...
    #7199
    Found a different one, mas malaki kesa sa pinakita nyo sa picture, pero 3/4 parin yung size.
    Ni shoot ko lang on top of the existing rubber stopper, maayos na. Less than a minute job hehe.
    Thanks! Ganda ng pagkabukas ng pintuan.
    #7200
    Talking about sliding doors, main source ng kalampag sa GS namin yan. Parang malalaglag kapag nalulubak.
    Did some observation and found out that this is one of the noisiest. The sliding door lock tab. Tried to stuff it with foam and medyo nawala. Eventually matatanggal din yung foam kaya maingay na uli
2008 Hyundai Starex (Gen. 4)
