Results 1 to 17 of 17
    hi,
    need help on finding a reliable a/t specialist. i drive a 2002 civic 1.5at lxi. biglang nawalan ng hatak habang umaandar, parang biglang nag neutral yung kotse. almost 4000rpm na bago mag shift uli yung sasakyan.
    brought the car to honda, and thy said that it was a transmission problem. quoted approx php60t for the repair. was wondering if there are those in the community who had this problem who can share where you had your car repaired (outside of the casa). di ko kaya ipagawa sa casa kaya sana may other options kayong matuturo. i live in quezon city.
    thanks in advance
    arnel
    loosing power? kahit anong tapak mo ayaw umarangkada? torque converter hula ko
    IMO get a surplus tranny rather than getting it repaired.
    EDIT: sa banawe marami surplus. just make sure na may warranty. usually kasi repair kits dont last more than 6 months.
    Quote Originally Posted by arnel_r View Post
    hi,
    thanks in advance
    arnel
    I'd recommend Mel Casaba. I'm there next week to have my Accord's A/T fixed. I'm still not sure if I'm going to go with a Rebuild/Overhaul or with a Surplus.
    Mainly because I can't source any original Honda rebuild kits and all I found were replacement kits made in the US.
    I don't like to gamble on a surplus unit, unless it came directly from a whole Accord that i test drove first, then had the A/T pulled and transplanted into my Accord.
    Try Jazz - Better Go with surplus. Malamang ang diagnosis ng Honda - "Bagsak Sir sa Line Pressure Test" tapos sasabihin... "Kailangan remanufacture"... Got that same comment.
    Thanks!
    Not sure kung andun pa itong shop sa may tapat ng Shell, along roosevelt avenue corner baler. Mura lang maningil at nagrerepair sila, look for Elmer.
    or this thread can lead you to one...
    http://tsikot.com/forums/transmissio...cialist-18809/
    Jan 2009
    Try AT Bulaong , kaliraya st sa banawe. Yung pregio van ko delayed ang shifting at mahina hatak.They overhauled my transmission and its working fine now. Mura sila sumingil at madaling kausap. Look for Alex or leonard bulaong. Highly recommended sila sa tsikot. Tel nos 7496586 or cp 09321477142
    Thanks for all the replies, will contact your recommendations. Read through the other A/T specialist thread also, same specialists were named. so i guess their works are really of high quality.
    *Mr.Z, same comment from Honda, ganyan din ang sinabi nila.
    Salamat uli and will update the thread on the results.
    arnel
    May 2011
    Try to call this cel. no. 09324333241 - Honda A/T specialist - Paranaque - forgot his name.
    Dec 2007
    try mo muna pa change ng atf sir...
    Jan 2009
    bilhin mo na kasi pare...
    Dec 2007
    mga sirs, any recommended AT specialist for honda cars na nasubukan nyo na?
    Check out Mel Casaba. Mayrun thread about his services dito sa Honda Cars Talk section. He works for a shop in Sucat (ANJ Tires), beside Cable Link and BDO (near Evacom area). I had my Accord AT checked and serviced there recently.
    Dec 2007
    kailan nyo po sir pinagawa yung AT ng accord nyo at ano po ang sira?
    *b16sir_stock - maintenance check lang tapos change oil na rin. Pina-check ko yung ATF ko, tapos nilinis na rin ni Mel Casaba yung throttle body at ni-adjust yung tappets. Oks pa naman daw yung AT ng accord ko, even though 2001 model pa yun. Also, while ni-check nya Accord ko, mayrun na nakaabang na next job nya. Mayrun nagdala ng sirang AT ng 98 Accord doon. Kelangan daw i-check ng maiigi ni Mel yun kasi di gumagana yung Reverse gear. Check nyo na lang yung comments sa thread about Mel Casaba's services.
    Dec 2007
    thanks sir...
    hopefully sana may magpost ng mg actual experience after overhaul ng AT tranny.
    Check nyo na lang yung thread na ito:
    http://tsikot.com/forums/honda-cars-...cialist-76569/
    You can then call Mel Casaba and consult him on your problem. Madali naman kausap yun.
A/T Specialist (02 Civic 1.5 LXi)
