Results 1 to 10 of 36
- Dec 2009
- 89
March 30th, 2015 08:40 PM #1If youre from the province, Jazz is not for you because of its low ground clearance. Mine is a 6 month old Jazz always touches the humps and rough roads, it breaks the trans cover easily, so goodbye Jazz. I had my tire flat, when i changed it, i noticed that the spare tire is 135/60/13, far from the bulit in tire whch is 185/65/15, and many more
March 30th, 2015 08:50 PM #2
I had that problem with my hatch, in my case the Accent diesel. Stock tires were 175 70 r14 (diameter of 602mm). Since you can increase the diameter as long as you don't go beyond 3% overall, I decided to shift to a 185 70 r14 (diameter of 616mm). Now I don't scrape the humps I normally do.
- Dec 2009
- 89
March 30th, 2015 09:34 PM #3yes, the least that i can do also change my car tire size maybe, 185/70/15.
- Dec 2009
- 89
April 1st, 2015 10:43 AM #6
That is correct...
And with the addition of mud guards on our City,- (my old school me)... ,- it is double trouble.... Much more complicated!
Halos lahat ng humps,- hinahalikan... Kissing bandit!... :hysterical:
26.1K _/_/_/_/_/:loopy:_/_/_/_/_/
- Apr 2014
- 62
April 1st, 2015 03:10 PM #7
April 1st, 2015 03:40 PM #8
- Dec 2009
- 89
April 1st, 2015 09:43 PM #9ok lang mga mudguards, accessories lang yan, ang trans cover ang ma damage, sakit ng ulo.huhuhuhuhhu
- Dec 2009
- 89
April 2nd, 2015 10:21 AM #10i was shocked when i saw the spare tire, a little bigger to a tricycle tire.
high idle RPM at engine start
