Results 1 to 17 of 17
  1. #1
    mga guys, sa tingin nyo, pwede na ba to? kahit jdm convert lang..mura lang din kasi,e..mas practical kaysa sa hatch or sedan dito....
    GENERAL
    Body type Wagon
    Drive FULL 4WD
    Transmission Super low attaching 5 speed / Low holdmechanism attaching 2WAY4 speed
    Displacement, cc 1590
    Frame E-EF5
    SPECIFICATION (SPECS)
    EXTERIOR
    Exterior dimensions (LxWxH), mm 4105 x 1690 x 1515
    Interior dimensions (LxWxH), mm
    Wheel base, mm 2500
    Treads (F/R), mm 1445 / 1455
    Ground clearance, mm 155
    Curb vehicle weight, kg 1160
    Gross vehicle weight, kg
    Seating capacity, persons 5
    Doors number 5
    Min.turning radius, m 4.8
    Fuel tank capacity, l 45
    ENGINE
    Engine model ZC
    Max.power (Net), kw(PS)/rpm 120 ps (88.26 kw) / 6300 rpm
    Max.torque(Net), N*m(kg*m)/rpm 14.5 kg*m (142.20 N*m) / 5500 rpm
    Power density 9.67
    Engine type Water cooling serial 4 cylinder SOHC
    Engine information Horizontal ranging
    Fuel system Electronic fuel injection system (HONDA PGM-FI)
    Turbocharger No
    Fuel type Unleaded regular gasoline
    LEV system (Low emission vehicle) No
    Compression ratio 9.2
    Bore, mm 75
    Stroke, mm 84.5
    Final gear ratio
    Fuel consumption at 10-15 modes, l/100km 7.5
    GENERAL
    Body type Wagon
    Drive FF
    Transmission Lockup mechanism attaching 4 speed / 5 speed manual
    Displacement, cc 1493
    Frame E-EF2
    Price of new car, thousands yen (Tokyo area) 1309 (~$10900)
    EXTERIOR
    Exterior dimensions (LxWxH), mm 4105 x 1690 x 1470
    Wheel base, mm 2500
    Curb vehicle weight, kg 1040
    Doors number 5
    ENGINE
    Engine model D15B
    Max.power (Net), kw(PS)/rpm 100 ps (73.55 kw) / 6300 rpm
    Max.torque(Net), N*m(kg*m)/rpm 12.8 kg*m (125.53 N*m) / 4500 rpm
    Power density 10.4
    Fuel system Carburetor system (2 reams)
    Turbocharger No
    Bore, mm 75
    Stroke, mm 84.5
    Final gear ratio
    Fuel consumption at 10-15 modes, l/100km 7.9L
    Apr 2004
    meron na nyan dito?? how much?? wagon fan din kasi ako
    i'm not a fan of converted vehicles. medyo kinakabog dibdib ko sa ganyan.
  4. #4
    may us version na ako nakitang ganyan, pero not for sale,e and some converted for sale sa bulacan/sa auction..prefer ko sana manual, pero puro matic.kung EF din yan, swappable ang locally avail parts for EF civics(siyempre, di lahat,ha!).slapping a d15a, or a b16 or turbo it will be a good start...(dami nang hatch,e!)
    may exp. na din naman ako sa restoration ng converted vehicles(i had 2 na, and trucks)
    kung di feasible, wira/astina nalang...pero rare ang dating ng shuttle,e...honda enthusiasts, what do you think?
    Apr 2004
    hmmmmm......di ka kaya mahirapan sa parts nyan?
  6. #6
    i'm projecting baka sa rear part, at kung 4wd system...pag may nakita me ulit sa auction/bulacan pag uwi, uusisain kong mabuti...bibihira kasi ito.
    sisilip din ako ng local EF-civics natin dito..
    kung di feasible, wira or astina nalang...wala nang 4-door hatch/small wagon na cheap lang (150K-below), except spacewagon.
civic shuttle
