mga guys, sa tingin nyo, pwede na ba to? kahit jdm convert lang..mura lang din kasi,e..mas practical kaysa sa hatch or sedan dito....
GENERAL
Body type Wagon
Drive FULL 4WD
Transmission Super low attaching 5 speed / Low holdmechanism attaching 2WAY4 speed
Displacement, cc 1590
Frame E-EF5
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4105 x 1690 x 1515
Interior dimensions (LxWxH), mm
Wheel base, mm 2500
Treads (F/R), mm 1445 / 1455
Ground clearance, mm 155
Curb vehicle weight, kg 1160
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 5
Min.turning radius, m 4.8
Fuel tank capacity, l 45
ENGINE
Engine model ZC
Max.power (Net), kw(PS)/rpm 120 ps (88.26 kw) / 6300 rpm
Max.torque(Net), N*m(kg*m)/rpm 14.5 kg*m (142.20 N*m) / 5500 rpm
Power density 9.67
Engine type Water cooling serial 4 cylinder SOHC
Engine information Horizontal ranging
Fuel system Electronic fuel injection system (HONDA PGM-FI)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) No
Compression ratio 9.2
Bore, mm 75
Stroke, mm 84.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.5
GENERAL
Body type Wagon
Drive FF
Transmission Lockup mechanism attaching 4 speed / 5 speed manual
Displacement, cc 1493
Frame E-EF2
Price of new car, thousands yen (Tokyo area) 1309 (~$10900)
EXTERIOR
Exterior dimensions (LxWxH), mm 4105 x 1690 x 1470
Wheel base, mm 2500
Curb vehicle weight, kg 1040
Doors number 5
ENGINE
Engine model D15B
Max.power (Net), kw(PS)/rpm 100 ps (73.55 kw) / 6300 rpm
Max.torque(Net), N*m(kg*m)/rpm 12.8 kg*m (125.53 N*m) / 4500 rpm
Power density 10.4
Fuel system Carburetor system (2 reams)
Turbocharger No
Bore, mm 75
Stroke, mm 84.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.9L
may us version na ako nakitang ganyan, pero not for sale,e and some converted for sale sa bulacan/sa auction..prefer ko sana manual, pero puro matic.kung EF din yan, swappable ang locally avail parts for EF civics(siyempre, di lahat,ha!).slapping a d15a, or a b16 or turbo it will be a good start...(dami nang hatch,e!)
may exp. na din naman ako sa restoration ng converted vehicles(i had 2 na, and trucks)
kung di feasible, wira/astina nalang...pero rare ang dating ng shuttle,e...honda enthusiasts, what do you think?
