Results 1 to 5 of 5
- Jan 2013
- 4
January 30th, 2013 06:46 AM #1sir's,
good day!,bumili kasi ako ng bagong gulong tapos nagpa align ako ng gulong ng esi ko sobrang laki ng offset ng cember ng front right pero ang toe ok naman..ang tolerance kasi ay +-0.15 tapos yung reading nung skin ay +2.28..
tanong ko po ay:
*ano ang kadalasang cause nun?
*ano ang pwede ko pang gawin para macheck?
*ano ang kadalasang pinapalitan?
*wala ba talagang adjustment ng cember ang honda?
thankyou in advance mga boss!!
January 30th, 2013 10:08 AM #2
normally, camber offsets are caused by the rough and tumble in our roads.... minsan may madaanan kang malaki lubak, mawawala yan, or frequent passing over humps. it can also be caused by defective suspension components like the rack ends and tie rods.
para ma check yan, you need to have an alignment check every six months. sa mga pinapalitan, pwedeng wala or depende sa condition ng suspension components.
not sure on the honda camber adjustment.
- Oct 2009
- 2,271
February 1st, 2013 02:25 PM #3wala nga yatang camber ang honda..
pero sa esi kadalasan suspension bushing ako dati every 6 months sira bushing.kakainis talaga sa esi kapag naka mags kana.
parang lalong humihina ung suspension mo..
February 2nd, 2013 02:37 PM #4
Wala Camber ang EK akin lagi sira ang stab link. pag mags talaga it gravely affects suspension life due to weight and size and most of all road conditions talaga natin dito masama.
Best to check alignment every 6 months since mis alignment can be caused by wear of suspension parts such as rack end tie rod end etc.... Unchecked can lead to uneven tire wear. Mura lang naman alignment sa mga service center and 100 lang pag hindi kailangan i align.
February 2nd, 2013 07:43 PM #5
regarding suspension bushings and stabilizer links, naranasan ko rin na madalas ako magpalit nito when I used replacement, so ang pinakabit sakin orig, ayun ayos na.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
