Results 1 to 11 of 11
    Dec 2008
    engine model?
    horsepower?
    torque?
    Type : Aluminum Block and Head
    Valvetrain :SOHC 4 valve/cyl (4-Door: 1.5 LXi)
    Displacement :1493cc (4-Door: 1.5 LXi)
    Bore x Stroke : 75x84.5mm (4-Door: 1.5i LXi)
    Power : 84kW (114Cv) * 6500rpm (4-Door: 1.5i LXi)
    Fuel supply system -Programmed-Fuel Injection
    Bore & stroke -75 x 84.5 mm
    Displacement -1493 cc
    Compression ratio -9.0 : 1
    Max. power -110 ps / 5800 rpm
    Max. torque -13.8 kgm / 4200 rpm
    Knock sensor -STD
    Dec 2008
    Quote Originally Posted by archie123456789 View Post
    Knock sensor -STD
    thank you sir, tagal ko na hinahanap yan. sabi kasi nung mekaniko nataga kaizen eh 75 hp lang daw lxi natin at underpower daw siya.
    Dec 2008
    btw sir, mas malakas pa ito kaysa toyota altis? ung sa wife ko 108hp daw eh, paggamit ko yun parang mas mabilis pa sya sa lxi ko.
    Dec 2008
    o.t. what modifications can we do to gain more horsepower for our lxi, tried simota air filter, all it does is accumulate dirt in throtle body, lagi nagloloko rpm ko.
    siguro dahil vtec na rin atils, mas may bubuga yun. no doubt mas malakas altis sa LXi, mas mabilis ako makahit ng 160kph sa altis namin dati. baka greater torque ang altis than LXi. sa LXi kailangan ng mahabang road para umabot ng 160kph unlike the altis.
    75hp yung LXi? hmmm... baka whp with full load. yung specs na yan hp lang talaga. not that sure though. honda casa specs po yang post ko.
    Quote Originally Posted by dahve View Post
    only way to gain power is IHE upgrade pero parang not worth it for me. get a better power plant na lang than spend on the upgrade. i think yung d15b 20 cams 30k - 40k kasama kabit. the IHE upgrade abot ka ng 20k (doing the right setup). kaya change engine na lang IMO.
    simota? i tried that before, walang gains and parang naging less torque pa than stock. ganyan din yung kinabit ko twister ko dati, kailangan linisin IACV and TB. kaya kinalas ko na lang then donate it to my friend.
    The Altis may accelerate faster than the LXi because of the torque difference.
    3ZZ-FE engine has 150 NM of TQ, while the LXi has ~135 NM of TQ at a higher RPM.
    Mas mahina yung LXi engine sa lower RPM range, while it's more powerful nearer to its redline.
    The higher torque = mas mabilis sa arangkada (lalo from a standstill)
    The higher HP = faster to reach top speed (esp when all other things held equal)
    There's probably a better/more correct explanation for this, pero ito na yung medyo simple.
    Dec 2008
    agree, nung nagsubic kami, dala namin ni misis yung altis '02 niya, 2 lang kami sakay, napaabot ko ng 180kph sa sctex, pero matagal din to reach that speed, di ko na sinagad kasi may parang beeping sound ako naririnig sa engine. nung dala namin yung lxi ko, hanggang 170kph lang sa sctex, long stretch to gain that speed at medyo downhill yung strech ng kalsada, 2 kami plus my mom and my lola na natutulog ang sakay, hehehe.
    Dec 2008
    whats IHE mean? d15b? ito ba yung vtec na 1.5? yan yung kinabit ng bayaw ko sa civic vtec '97 nila, mas matipid daw sa gas. bumigay na kasi yung orig. engine nila kaya bumili ng surplus.
    IHE = Intake, Headers, Exhaust. to get the full potential, dapat hindi bara bara yung gamitin. headers will cost around 10k mandrel bend, exhaust, another 10k - 15k then the intake, ill go with H&R another 5k -7k. all in all mas ok yung change engine. instant power.
    ang alam ko d15b 20 cams mas malakas sa gas. baka yung kinuha ng bayaw mo yung economy implement vtec kaya mas matipid.
what is the ebgune specs. of honda civic lxi 1999?
