Results 1 to 10 of 19
- Dec 2006
- 8
November 25th, 2009 12:37 PM #1Mga sir tulong naman po..napansin ko lang po sa car ko na 1996 Honda VTEC pag umabot na ng 60kph bakit nanginginig ung car ko..pina align ko na, wheel balancing and replaced new suspension bakit ganon parin..any Idea po kung sa engine ito or suspension problem? Please advise po kung ano dapat gawin..TIA
- Apr 2009
- 28
November 25th, 2009 12:49 PM #2Sir, d ko lang sure kung ito ba un, may gnyan akong issue nun ang naging problem ko ung gulong, bilog na so pinalitan lang ung gulong ng brand new um-ok naman, ung car ko po is a 1997 Mitsubishi lancer GLXi, sana makatulong ahehe
November 25th, 2009 12:54 PM #4
look for signs of severe uneven wear in your front tires because its possible that even though you already had it aligned if your tires are severely worn out your tires would still wiggle at high speeds so chances are you'll have to change tires then do an alignment again. but if your tires are fine then it maybe a poor job alignment.
- Dec 2006
- 8
November 25th, 2009 01:06 PM #5Mga sir meron pa po ba possibility na sa engine mang galing ung nginig? what happen po kaya kung hindi nag activate ung VTEC?
- Mar 2007
- 44
November 26th, 2009 02:36 PM #6
- Dec 2006
- 8
November 26th, 2009 04:46 PM #9Mga sir posible rin ba na maging shaky at 60kph dahil may check engine? pina check ko may error daw sa knock sensor (tinanggal ung sensor) at crank fluctuation sensor..pwede kaya maging dahilan ang mga yun? or suspension or sa Goma lang talaga? I need you advise mga sir..TIA
November 27th, 2009 10:37 AM #10
bro isa isa lang.. pa check mo muna yung mags o gulong mo. either binkong mags mo or oblong na gulong mo. ngayon pag hindi yun, saka mo na tignan yung ibang possible cause, hirap mag diagnose ng sabay sabay.
Just ordered backup charger. Will keep you updated...
