Results 1 to 16 of 16
    Jan 2010
    sir, i had my car checked sa honda. this is what they quoted me for
    1. overhaul gearbox assy
    2. overhaul p/s pump assy
    3. replace lower arm assy (front, both)
    4. replace shock absorber (from, both)
    ung item 1, since indi nila maoverhaul.. they had it replaced.
    ung item 3, ok na din ung lower arm ko.
    ung two items plang ang npapagawa ko.
    now, may ingay akong naririnig sa hood ko when driving the car or after driving while the engine is still on.
    ung noise is same as when the A/C is on.
    sometimes, nawawala ung ingay pag i-ooff ung A/C.(take note, "sometimes")
    i had it check sa local mechanic at sbi replace ko daw ung A/C compressor.
    which do u think is true? AC compressor or PS pump?
    Jan 2009
    Establish first what kind of noise? Can you describe the noise in words (ie. squeaking, grinding, whining, hissing, rattling, etc.)?
    Pa check mo muna sa gawaan ng car aircon baka bearing ng aircon compressor ang naririnig mo.
    Jan 2010
    thank you for all your replies.
    it is more of a rattling noise that sounds like a pulley bearing noise.
    it is particularly loud when i turned on the A/C while accelerating.
    Jan 2010
    sir, compressor daw po ung problem according to the mechanic.
    they want it replace for 3.5k (surplus) then 1.5k for the labor.
    loose na daw ung bearing ng compressor and it can't be repaired daw po.
    what must i do?
    pls help.
    Jun 2009
    Quote Originally Posted by bang 2010 View Post
    what must i do?
    pls help.
    Compressor bearing can be easily replaced as long the mechanics have the right tools (Bearing puller, bearing fitting tool, circlip pliers,etc) for the right job. Thats the trouble with some backyard mechanics, if they can't repair a certain component, just replace with a surplus/ used one.
    Feb 2010
    sir meron kayo idea kung how much compressor sa honda esi 94? tnx
    Jan 2003
    sir, just to be sure whether the A/C comp. or PS pump is the culprit, try elimination. the two have separate belts attached to the pulley. first remove the comp belt, observe, then replace it. next, remove PS pump, observe. im sure after that you will be sure which is making the noise. HTH.
    Jan 2010
    thank u po sa suggestion nio.
    naka apat na mechanics na po ako. 3 po dun e A/C mechanics, lahat cla compressor ang tinuturo. well i dont think they check the P/S pump.
    how possible is it na P/S pump ang problema? do they create the same noise?
    i know soooooo little about cars.
    that means, i can only open the hood and the trunk. nothing more. except to drive ( a little).
    i wish i can try your suggestion.
    or ok lang po ba if i ask the mechanic to do what u ask me to try? --- isolation?
    repeat ko lang po ung instruction.
    1.first remove the comp belt, observe, then replace it. (what will i use to replace the comp belt?)
    2. remove PS pump, observe.
    Jan 2010
    good morning.
    finally i had the compressor fixed.
    initially bearing lang daw ung problema so i was charge 2.5k
    after iopen at iremove ung compressor the mechanic told me na its not only the bearing but the clutch plate as well. so almost the entire compressor head e papalitan na daw nia just to save my comp. i need to pay 3.5k na daw.
    otherwise, ibabalik nia lang ung dinisassemble niang parts.
    i decided na ipatapos nlang.
    after that pnakita nia sa akin ung mga broken parts like the bearing and clutch plate.
    then he showed me ung compressor na nkakabit na sa sasakyan.
    one thing i noticed is that, iba na ung color ng compressor ko.
    naging white silver. he told me na nilagyan nia ng paint after linisin.
    im afraid na pnalitan nia ung compressor ko since orig pa un at still working. how will i know na ung compressor head lang ung pnalitan nia and not the entire compressor?
    nkakalungkot talga magpafix ng sasakyan.
    Mas maganda siguro kung pagagawa mo sasakyan mo bantayan mo iyong paggawa para nakikita mo piyesa na pinalitan kasi kung nakatutok ka hindi sila makakagawa ng palitan ito ng iba. Suggestion lang sa mga nagpapagawa.
P/S pump or  A/C compressor?
