Results 1 to 9 of 9
    Sep 2009
    Gud day. Ask ko lang kung ano possible reason bakit umuugong un car ko * 100kph pataas? I was driving at NLEX and SCTEX kaninang umaga nung narinig ko un ugong. '01 VTI manual un car.TIA
    Dec 2004
    Check power steering lines, might be vibrating at high speed?
    Quote Originally Posted by holla2yurboi View Post
    when was the last time you have your wheels balanced? alignment? how about your brakes and suspension, when was the last time you have them checked?
    From where is the sound coming from? Is it from the engine compartment? From under the car? From behind?
    Jan 2009
    Another source would be the wheel bearings.
    paikutin mo sa wheel balancer and im sure you'll see why it wiggles at 100kph.
    Sep 2009
    *archie123456789 and *oj88-I will try and have it checked if those are the culprits
    *CivicVTi-Yes Sir, I think it's from the engine compartment
    *aejhayl17- no idea Sir, just got the car last week
    *corbon44-may leak nga ata sa PS reserve
    Tnx Sirs, much appreciated.
    Good day!
    If the sound is coming from the front, it may well be from the front wheels/suspension, from the transmission, or from the engine itself. I suggest taking the car to a competent mechanic/shop. Have them test drive the car with you if possible so they can isolate the strange noise.
Ugong * 100 kph
