Yep sleepsus. ganun na nga. By the way, I'm using NGK spark plugs. Baka mamaya pa tune-up ako then malalaman natin kung yung timing nga talaga ang nagttrigger ng hard starting ko. There is a possiblity that my distributor is set to advance or retard. Balitaan ko kaya. Thanks sa tips and if you have any just keep it coming. More heads are better than one. :D
*hyblaxx_24
it seems that resetting (distributor) your timing to advance or retard didn't help resolve the issue of hard starting when your engine is hot. i had to bring my car to a good mechanic with timing tester or sensor to reset the timing. pero ganun parin. tinakbo ko ng approximately 1 hour na naka-on yung lights at aircon. nung pinatay ko sa parking lot, then turn on ulit, hard starting pa rin.![]()
nangyari na din sakin yan....akala ko kc hard starting sya everytime you start the engine...tanung ko lang pag mainit ang engine ayaw mag start or hard starting?kailangan mo p b palamigin bago mo start?yung nang yari sakin di ma start ang engine pag hot kailangan ko pa palamigin kasi sira na yung starter ko.try mo pa check baka stck-up starter k..tnx
try to return it and check..kasi nung nasira starter ko sabi ng mekaniko ng tito ko 2 choices paayus ang starter or paltan ng surplus..ginawa ko pinaltan ko na lang ng surplus just for 2500php sabi kasi ng mekaniko ng tito ko sasakit lang ang ulo ko pag pina repair ko ewan ko lang sa iba na nag rerepair.pag maiinit na b yung engine mo may nararamdaman k b na vibration?parang kapos sa supply?yung before sakin ganun ang nang yari ang replace the ignition coil.tnx..
thanks for your responses.i really appreciate it.
if that is ignition coil, me possibility nga. papatingin ko na rin.'yung sakin kasi kapag mainit na ang makina wala naman akong nararamdaman na vibration na tulad ng na-experienced mo. pero sige, papatingin ko na rin. thanks
sir, yung oem na thermo switch P1,350 brand new. pero pwede ka makahingi ng discount, simplehan mo na lang. :D labor ko kay rey's free na e. suki kasi ako dun. parts na lang talaga ang binabayad ko. pero malamang, kapag bumili ka ng thermo switch dun sabihin mo baka pwede free na yung kabit since mahal naman yung parts. hehehe. kung marunong ka naman mag diy, ikaw na lang ang magtanggal, madali lang naman yun. gamit ka lang ng 14" or 15" socket. hope it helps. :D
mga paps, maraming salamat sa inputs. ok na yung auto ko. nakipagswap na lang ako kay rey ng starter. from civic oem starter to honda accord 2003 model ata yun na gear-reduction starter. swabeng-swabe ang start. kahit mainit ang makina ayos na rin. walang palya. so far ok siya. sana tuloy-tuloy na! hehe. maraming salamat! :D
nangyari sakin yan.. parang naging tunog pump boat ung oto ko haha! dami ko pang chneck... palit pa ko high tension wires, spark plugs, pacheck comp engine, fuel line, fuel filter, idling, etc. ndi pa din nasolve!!! langya ang problema lang pala e.... kinain ng daga ung wirings ng oto ko kasi nastock un for 9mos hehe! aun back to normal na..![]()
nasolve na po ba problem na ito. i'm having the same problem with my toyota fx. kapapalit lang ng cylinder head ko. pero pag nag aircon na ako, nag ooverheat tapos namamatay yung aircon. patulong naman po. malaki na rin nagasto ko e hindi pa rin maayos. ipunta ko nalang kaya sa toyota service center kahit mahal... wat ja think?
tama si airolynx. paki check mo muna yung sa list niya. ganun din sakin e. process of elimination talaga, mejo mahirap kasi madetermine agad kung ano ang culprit ng sira ng auto mo. oem ba yung pinalit na cylinder head gasket? dapat palit piston ring, valve seal pag binuksan yung top ng engine.
