Results 11 to 20 of 33
September 21st, 2010 04:06 PM #11
September 21st, 2010 04:09 PM #12
[SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format.
Learn to spell properly so others can understand your message.
Read the RULES.
Ignorance is NOT an excuse.
Repeated offenses will lead to banning.[/SIZE]
- Jan 2006
- 18
September 21st, 2010 04:19 PM #13i had the same problem a year ago. tried replacing the atf and filter. um-ok for 2 weeks then same symptoms na naman. pag matagal na stop, ayaw mag-accelerate tapos sobrang taas na ng rpm. sometimes, i would try using d2, ayun ok ulit. pero temperorary lang yung relief. instead of having my transmission overhauled, i just bought a surplus unit (11K). 2K for labor kasi 2 days yata ginawa and another 2K for atf kasi after a month, nagchang atf ulit ako just to make sure na wala na yung luma. i experienced this after reaching 100K mileage. sinusunod ko naman yung pm sched pero ganun pa rin. end of life cycle na ata. pagkatapos ko palitan, ok na. back to normal takbo.
September 21st, 2010 04:27 PM #14
September 21st, 2010 04:42 PM #15
oo nga, para ding makina na may life span para sa next overhaul....
Paano ba mapatagal ang serbisyo ng Transmission?
Of course, sa pagsunod sa ATF viscosity at right time sa PM.
Sa traffic, kapag idle ka lang, ilagay ang kambiyo sa N o Neutral.
o di kaya sa P o Park sa gayun di naka-engage ang mga mechanism nito sa loob ng transmission o yung mga clutches nito sa loob....(LALO NA YUNG PATAAS KA O SA TULAY NA PALUSONG)
Sa pagkambiyo, kapag nasa N, wag mamihasa na ikambiyo sa D o Drive nang hindi tinatapakan ang brake pedal...sa gayun di din mastress Transmission...(kalimitan nakakalimutan na natin ito.....)
Basta kapag nagshift ng kambiyo, laging tandaan tapak muna sa Brake pedal, para safe din...
me dagdag pa ba?
September 21st, 2010 04:53 PM #16
September 21st, 2010 04:57 PM #17
- Jun 2010
- 5
September 21st, 2010 06:09 PM #18sorry doon sa text format, won't happen next time, anyway my car is due for ATF change and other PM Services, hope na yun lang problema, salamat sa mga reply
- Sep 2010
- 8
September 21st, 2010 11:31 PM #19
high idle RPM at engine start
