Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    Feb 2018
    I have cheking the the dip stick for two weeks. There is no change on the level. I took the car to the mechanic yesterday. We turned the aircon on high, rev the engine a couple of times and there is no smoke. The mechanic told me to take a video if the smoke appears again. I think it happens if the engine is cool and the load is heavy.
    Sent from my D6503 using Tapatalk
    Quote Originally Posted by Ethan0410 View Post
    when oil is burned in the combustion chamber, the tailpipe smoke is black.
    if the smoke is white, it suggests water leak, getting into the combustion chamber. check your coolant levels, po.
    if it is low, then that white smoke from your tailpipe is probably water vapor. see my comments above.
    Feb 2018
    hi sir dr. d ask ko lng po kung head gasket na din po yung problema ng adventure ko 4G63 engine. 2003 model, nakargahan po ng diesel nung nagpa full tank ako. 530 worth po naikarga, estimated ko 1500+ yung dating karga na gasoline. nalaman ko lng nung umuusok na pina drain ko, ang ginawa nung mekanik pinalitan lng ng fresh gas yung tank tapon piaandar ng pinaandar hanggang maalis yung usok. after 2 weeks may konting usok na na may kasamang tubig lumalabas sa tailpipe. yung coolant ko po nagbabawas sir, dumadami laman ng reservoir kapag maiinit na makina tapos sinisipsip ulit kapag malamig na makina. chinicheck ko yung oil dip and oil cover wala naman sign na nag mixed yung tubig sa oil po.. pa advice naman po please.
    Quote Originally Posted by Jomar_05 View Post
    normal lang yang taas-baba ng coolant level sa reservoir. palipat-lipat lang si coolant, between the reservoir and the radiator.
    as long as you are not losing coolant. observe for a few days, if you are really loosing coolant and you have to add more. good cooling systems hardly need topping-up for months to years.
    water from the tambucho, is normal, during the first few minutes of starting.
    Feb 2018
    sir pano po kung dun sa reservoir kapag ina accelerate yung sasakyan meron mga bubbles na lumalabas? napansin ko din po sa tambutso kahit matagal na umaandar meron pa din moist na naiipon para meron tumulo na tubig ( meron po takip tambutso
    bumabanga muna kaya pababa labas) pwede pa po ba gamitin ng gamitin sasakyan?
top overhaul.
