guy's i have a 60mm autogauge tachometer..the problem is how i will install that stuff? black is ground,red is acc and blue is singal...what color will i tap in distributor wiring...base on the guide/manual they din't specify the color of the wire that should be tap on the distributor wiring..any answer?speed unlimited need some advise..ph15 car engine.thanks in advance...
