Page 1 of 2 12 LastLast
Results 1 to 20 of 51
    Feb 2010
    Guys meroon na bang CITY na A/T 04-05 na me 120K plus na mileage? musta na po maintenance? ok pa rin ba? Thanks!!!
    Nov 2014
    Up naten ito.....meron nga ba???
    Mine 2004 city vtec 1.5 engine * 115k ok pa naman....
    Share nyo naman sa inyo guys.....
    Aug 2014
    Mine is a 2005 AT iDSI. i have a very high milage na but no major problem naman (Sana)
    Minor is from N to D minsan mag vibrate muna bago umusad pero bihira naman. maybe its time to replace CVT oil na.
    Guys, Whats your iDSI At experiences? share naman to this thread or at least give us links.
    Nov 2014
    Quote Originally Posted by page7fordoddie View Post
    Sir page ilan mileage ng city mo??? Kindly share pati tuwing kelan ka ba nag papalit ng transmission oil??? Are you using CVT oil on your tranny???
    Aug 2014
    Check ko later yung actual Odo reading ko Boss then will post it here. Actually, just got my car few months ago (2nd hand) pero sabi every two years daw ang palit ng CVT oil sabi ng Honda Otis nung last ko magpa change oil. hindi ko kasi napasilip yung CVT oil.
    Will update this thread ASAP.
    Nov 2014
    Kung kakabili mo lang ng city mo better palitan mo kagad CVTF oi baka kse ordinary oil lang ginamit dati ng may ari eh maselan daw tranny na CVT dapat regular change oil pati every year dapat not 2years nabasa ko lang d2 sa thread....
    Update us asap sir kung ano development sayo.....
    Oct 2003
    Yung sa akin nasa 157xxx kms already. Changed the flywheel once.
    Nov 2014
    Quote Originally Posted by zechs View Post
    Zechs what happen sayo why change flywheel??? How much inabot sayo??? Sa CASA mo pinagawa???
    May 2011
    Hello po,
    Yung sa kin 2007 city 1.3s Idsi, millage: 94xxx, last month palit ako nga Honda CVTF and Change oil na rin, akala ko makuha yung pag Reverse mo minsan parang na choke/loss or parang may biglang may umapak ng break. Pero sa ibang gears smooth ang takbo at andar ng engine. Any idea po? sana wag flywheel. Thanks
    Quote Originally Posted by gsh0ck View Post
    Hello po,
    i hope it's only flywheel... but i doubt it.. the rest are, unfortunately, potentially more expensive to fix..
    good luck.
    May 2011
    good luck.
    Follow-up question po, makikita ba sa diagnostic tools kung mag tama na ang flywheel? Thanks
    Jul 2012
    Hello po,
    signs na po yan ng bad tranny. my jazz had the same reverse issue, hindi ko alam na early signs of bad tranny. changes the cvtf every 20k. recently lumala na yung problema.. once it starts.. it continues and it gets worse when you least expected. planning to have my tranny replaced within the month.. grabe na tlga eh.. baka one day tumirik na lang. balak ko after palit tranny, yung palit ko ng cvtf isasabay ko sa change oil
    Nov 2014
    Quote Originally Posted by nashimoto View Post
    Bro nash malapit ka na pala mag palit tranny balitaan mo kame result ah....kay pareng mel mo ba dadalin pre?
    Jul 2012
    Hello po,
    jan nagsimula yung issue ng jazz05 ko.. not knowing na tranny issue pala. sa simula ok nmn oto ko pero yung nga minsan palyado reverse until after ilang gamit ayun pati D may issue narin.. and eventually it leads to a tranny issue na tlga.
    Jul 2015
    Is it true na mas mahal ang maintenance ng A/T compared sa manual? Thanks!
    Quote Originally Posted by carskeptic View Post
    True.
    Sent from my UP+ using Tapatalk
    Oct 2003
    Same symptoms as the rest. Jerking when reversing or starting from D
    Why not flywheel lng palitan buong tranny tlga?? Prang clutch lng dn nmn yan wear and tear.
    Mga sir sorry if OT.
    I am about to buy 2008 idsi CVT. 80k+ milleage for 240k.
    Ni road test ko sya. nag tataka lang ako pag nag switch ako sa S mode nag chachange gear din sya ng kusa in less 4k rpm. Di ko pa na hihit ung + button. Same din po ba sa inyo?
    Pa explain further naman po ung S mode. Ang alam ko kasi it will work like manual tranny pero di ganun nangyari sa road test ko.
    2nd is ung blower ng AC di kasing lakas ng blower ng ibang oto. Normal ba un sa ganitong model?
    3rd is..pag nag S mode ba need pa i press ung 7 speed sa steering wheel?
    Pa explain po
    Thanks in advance!
    May 2011
    Quote Originally Posted by georgejr05 View Post
    Normal lang sir pag hindi nyo na hit ang + button, kusang nag shift yan at sa pagkakabasa ko nasa 3K - 4k rpm, kung nasa D mode ka usually nasa 2k-3k rpm mag shift basta hindi mo ginalaw yung + button
    S = Sports mode, ang pagkaka-iba lang po sa D, yung RPM range bago mag shift, off course mas matagaw sa Gas yung S
    Sa akin oks kahit 1 lang yung blower ko malamig naman sa loob, except pag bilad sa araw.
    Kahit hindi mo gamitin sir, ang explanation nasa taas ko na comment.
    Thanks in advance!
    Make sure mo lang sir na wala kang maririnig na anomang ingay sa Tranny, engine, tapos dapat walang delay sa shifting, walang Jerking, stall, vibration.
    Hope this help.
    Thanks in advance!
    Hope this help.
A/T HONDA CITY 04-05 (questions)
