Results 1 to 6 of 6
    Sep 2008
    Whats the tire pressure on your V guys? TIA
    May 2007
    Always go with what the car says. Even a tire shop will tell you the same thing. Tire pressure is determined by the weight of the car. Even if you have different sized tires, that's the correct pressure. If you like, you can add a few lbs of pressure to get a little better mileage but increased tire pressure decreases the contact patch of the tire and will effect grip, so don't go too high. Max pressure on the tire is to tell vendors if the tire is compatible with certain cars by weight.
    Sep 2008
    up ko lang guys
    Aug 2005
    city driving and 2 passenger average, 30psi - 32psi.
    Aug 2004
    Same here... about 30-32, as recommended on the door panel.
    Jan 2008
    30 psi.. that's the average
Ideal Tire Pressure for 07 CRV
