Results 1 to 10 of 10
    May 2009
    Sir, ask ko lang kung mura yung H22A sa 45K pag my transmission 70K? pwede ko ba ipalit sa SOHC VTI ko yun? If ever anu po kaya ang papalitan na mga parts sa pang ilalim ko? TIA
    May 2007
    Quote Originally Posted by rai711 View Post
    Get the ECU also. Sure it fit on your engine bay, I just dont know exactly how my friend did in his Civic. The H22A is a 2.2 engine DOHC VTEC 220 hp/163 ft./lbs of Torque and it came out from Prelude SiR (JDM). For 70K including the tranny, boy take it, dont ever leave the place or take away your eyes on the engine cause thats a bargain. Here in states it cost like $2,600 just for the engine not including tranny, if you found one.
    Just make sure its a H22A SiR S-Spec.
    BTW, having a heavy H22A engine in a Civic will affect its handling.
    May 2009
    Quote Originally Posted by v6dreamer View Post
    Sir how will I know if its H22A SiR S-Spec? the mechanic just inform me that the engine is H22A. I'll check the serial number of that engine.
    Ouch! is there anyway that I can fix that sir GH?
    Mga Sir...Thanks for the Infos
    You can't change physics. Also heavy engine would require stiffer springs, which would affect ride quality. Using typical Civic aftermarket springs would just bottom out every time you encounter a road speed bump or a pothole.
    I know this because I have a SR20 engine in my Sentra. I had to use very stiff springs to avoid bottoming out my front suspension on every bump I hit.
    Something else to consider.
    May 2009
    Hmm..change the suspension into stiffer springs,what else...shock absorber ?..Waaaaaaah I need a deeper pockets
    Thank you guys
Sir need advise in Change engine
