Guys help…
Now ko lang naexpience to sa Honda esi matic ko…erratic starting… ok naman battery ko… dati pag hirap start..tatapakan ko lang konti gas pedal start na siya… now hindi na… may ilaw naman lahat.. panel gauges, headlight etc..
Bago ko to naiexperince minsan hindi sya nag start when shifted to PARK… so what I did is shift it to NUETRAL.. ayun nag start naman… tas minsan nag start din on PARK pero erratic siya.
So it goes on for a couple of days starting up on NUETRAL…. Kanina hard starting na sya.. so I pass it over pinahinga ko ng mga 3 hour tas gumana ng kanina shifter on NUETRAL inikot ko sa village naming.. ok naman ang harurot tas pinahinga ko ng mga 30 minutes after ko inikot… now ayaw na naman magSTART. Any one experience the same?
Before this happen I remember na bigla nalang ako namatayan ng makina while idle kahit aircon off. And also while driving on EDSA las Wednesday nakaexperince ako ng RPM frop to 500 while AIRCON ON. May normal RPM is when I got the car few months ago is pegged at 800-1000 pag aircon on 1200.
Naka fabricated IDLE UP ACTUATOR na din pala etong ESI ko… the mere purpose na lang SERVO is for ECU detection.
Ano suggestions guys? Hirap pa naman ngayon holiday..
Hay SOS guys. Thank you!
Guys help…
