Results 1 to 8 of 8
    Mar 2005
    guys, paano alisin yung back seat ng honda civic ek? gusto ko sana tanggalin muna yung seat cover kasi madumi na. thanks
    Apr 2004
    lower seat first, ung sa pwet... there are two locks sa ilalim nyan, sa may gilid. pull those up. then slide it out.
    from there you will see two brackets with 14mm nuts. remove the nuts, then push the seatback up to disengage the locks sa likod near the rear nyan. pag natanggal na, (there will be 3... L, R and center), pull out.
    Jan 2009
    ^ Not sure about that one. Our EK before had something like 60/40 folding seats at the rear. To remove the lower part, there are two locks in front and one bolt at the rear, somewhat off-center to the left. You should remove this bolt (marked "D")before unlocking the two clips in front (broken circles).
    You only need to remove the lower part, after which, you can work on the two back rests by folding them forward.
    Mar 2005
    ^ ayun. hinanap ko kanina yung clips sa may gilid, wala ako makita. try ko naman sa rear. complicado pala alisin backseat ng civic. hehe
    tnx po vc and oj
    anong civic? alam ko walang 60/40 na rear seats na lumabas sa local. if then, tama yung post ni volt. ganon ginagawa ko.
    pag 60/40 ok yung kay oj88.
    simple lang yan bro. almost araw-araw ko binabaklas rear seats ko dati nung nag aayos ako ng sound setup. hehehe
    Jan 2009
    Quote Originally Posted by flakez View Post
    My bad . Yung dating Sentra pala yung naalala ko na may folding rear seats. Tinanong ko driver ni ermats, at yup, fixed pala sandalan nung EK namin. Sorry for the confusion.
how to remove back seat of a civic ek?
