Results 1 to 8 of 8
- Mar 2005
- 354
May 10th, 2009 08:05 PM #1guys, paano alisin yung back seat ng honda civic ek? gusto ko sana tanggalin muna yung seat cover kasi madumi na. thanks
May 12th, 2009 07:44 AM #2
lower seat first, ung sa pwet... there are two locks sa ilalim nyan, sa may gilid. pull those up. then slide it out.
from there you will see two brackets with 14mm nuts. remove the nuts, then push the seatback up to disengage the locks sa likod near the rear nyan. pag natanggal na, (there will be 3... L, R and center), pull out.
May 12th, 2009 08:52 AM #3
^ Not sure about that one. Our EK before had something like 60/40 folding seats at the rear. To remove the lower part, there are two locks in front and one bolt at the rear, somewhat off-center to the left. You should remove this bolt (marked "D")before unlocking the two clips in front (broken circles).
You only need to remove the lower part, after which, you can work on the two back rests by folding them forward.
- Mar 2005
- 354
May 13th, 2009 02:55 PM #4^ ayun. hinanap ko kanina yung clips sa may gilid, wala ako makita. try ko naman sa rear. complicado pala alisin backseat ng civic. hehe
tnx po vc and oj
May 13th, 2009 03:40 PM #5
anong civic? alam ko walang 60/40 na rear seats na lumabas sa local. if then, tama yung post ni volt. ganon ginagawa ko.
pag 60/40 ok yung kay oj88.
simple lang yan bro. almost araw-araw ko binabaklas rear seats ko dati nung nag aayos ako ng sound setup. hehehe
May 13th, 2009 04:29 PM #6
May 14th, 2009 08:19 AM #7
to the threadstarter:
i suggest you have the seats removed sa carwash na lang. dun sa sanay magbaklas nyan (ie, yung mga maraaming nagppahugas na civic).
when i was younger, ako lang nagttanggal ng mga yan, tapos palit seatcovers. medyo mahirap, papawisan ka talaga.
now i'm 30, parang hihimatayin nako when attempting to do so. the upper brackets where the seatback is held ay mahirap tanchahin kung nasan pag binabalik mo na. pag hindi mo naisukbit yung isang clip maluwag naman.
- Mar 2005
- 354
