Results 1 to 2 of 2
- Mar 2010
- 38
November 7th, 2011 12:58 PM #1Hi Folks,
Do you have any recommended honda civic car shops in Paranaque and Las Pinas area?
My ABS indicator light on my Civic 2005 VTI-S is ON while I'm driving the car. I notice that this happens when I have rear passengers. I presume that it must be my rear sensors that I would need a mechanic to check.
Can you recommend a car repair shop in Paranaque or Las Pinas where I can have the car diagnosed and replace the sensor if needed? I'm afraid the casa charges too much for this type of repair work.
thanks.
- Jul 2010
- 165
November 8th, 2011 07:05 PM #2Sir you can try and visit Hongly/Pitworzk at Dr A Santos Ave. If you are coming from SM Sucat just pass by Shell station and after a few hundred meters you will see it. The shop is also on the right side same as Shell station. You would hardly miss it since most of the cars being fixed are Civic's
high idle RPM at engine start
