Results 1 to 5 of 5
    Jun 2011
    the cap of my reservoir was loose thread. do i have to worry? is there any connection of this reservoir cap with my cooling system? thanks...
    Quote Originally Posted by milesaldrich View Post
    Not much problem sir. If you can put a teflon tape (the one used for water connections) in the threa to make it fit somehow again ok na yan. Or maybe a simple rag as pangbara will be enough.
    you should be ok. as long as it is secure and the hose that goes into it still works
    Jun 2011
    thnaks for the replies...
    ok lang yan... but if you have time, try having it replaced since minsan kapag hindi gaano sealed eh source of leaks/evaporation
radiator overflow reservoir  cap
