Results 1 to 3 of 3
- Jun 2009
- 44
August 5th, 2009 11:20 PM #1Mga sir,
my ride is ph16a honda civic 1997, medyo mavibrate na sya pag umaandar tapos medyo maingay na din yung makina and isa pa my parang screech and parang frictioning sound around "belts" area (engine bay,driver side) ,anu po kaya ang problema nito?need help po..thank you in advance
August 6th, 2009 09:13 AM #3
ENGINE VIBRATION: Tune-up you car (change oil, filters and spark plugs); Best to check the engine mounts too.
NOISY BELTS: As ghosthunter already mentioned, check the tension of the belts, you may need to adjust or simply (and recommemded) replace them with correct-sized belts
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
