Guys, help naman with my problem. I have a honda hatch EG, then I change my engine to D15b. They only convert my gas tank, they did not change the whole Gas tank. I notice, every-time I get out of the car, may naamoy akong gasolina, Then when I check yung ilalim, may nakita akong tagas ng gasolina. I check kung saan nanggagaling yung tagas, and I found out gaing sa fuel pump. I replace the rubber gasket ng fuel pump. then after a few days, may naamoy na naman akong gas, I check again kung saan galing, I found out, dun naman sa float. And I notice, eveytime I open my tank, may pressure na nabibuilt. Medyo napansin ko lang, parang nag expand na yung tangke ko. So meaning, may nagegenerate na pressure sa loob. I'm wondering bakit walang breather yung tangke.
There are only 2 line from tank going to engine. 1 for supply and the other one sa return. Then, I check yung ilalim ng tangke, meron pang 3 hose. yung dalawang hose, pinag short, then yung isa pinasakan ng turnilo.
I'm wondering baka yun ang purpose ng purge tank, wala kasing nilagay na purge tank sa kotse ko. where in dati namang meron nung naka PH12 pa lang ako.
Does anyone of you knows or have a diagram how to install a purge tank? Does it help para mawala yung amoy gasolina, and maiwasan yung pag bibuild ng pressure sa loob.
Meron pa akong nakikitang sakit eh but ito na lang muna ang ask ko.
Thanks and hope somebody will help me.
