Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Dec 2008
    I own a 99 civic, with 15" mags, ang tire ko is P185/65R15 (not sure if 65 or 55, I noticed that my inner front tires is worn out, tumatama sya dun sa kaha ba tawag dun, pag nakafull lock ka sumasayad sya, ano pa ba magandang gamitin na tires sa 15" na mags, sa tingin ko d naman nakalowered iyong springs ko e, pag lumiliko lang talaga ng todo, I really need to replace it mahirap na. thanks
    Nov 2007
    Quote Originally Posted by wilnor View Post
    I think you should try the stock civic sir specifications....if I'm not mistaken it's 195x55x15....good luck and hth.
    May 2007
    65 are too big, try 195/45-50/15.
    If you change your original wheel into 15" probably you bought with wrong offset. The more positive the offset, the further in the wheel into the inner fender. Yours actually have more (negative) inner fender clearance by having a wheel with a less positive number for offset. Again, check your tire first, if you think offset is not an issue, change your tire.
    Dec 2008
    Quote Originally Posted by v6dreamer View Post
    say the problem is the offset? how much does it actually cost? if I put more positive offset is there any disadvantages? actually I just got this used car last week, and the agent told me that it has 17" attached to it, if he bought it with the 17" mags it will be more expensive, so I just bought used 15" mags, (I'm not quite sure if I'm gonna believe that guy agent kasi.hehe)
    Dec 2008
    san po ba pwede mgpacheck ng ganito? dun po ba sa mga ng a-align pwede po ba dun? thanks po again
    Aug 2004
    It's not the mags or offset, it's the tires... 185/65R15 is just way too much for the Civic.
    actually, this is an offset problem. are you using an aftermarket rim? hindi sya stock?
    and yes, the max i think it can go is 185/60/15.
    May 2007
    It has everything to do with fitting wheels. You can ask the sale's person where you bought your wheel.
    Offset is basically how far away the mounting surface is away from the center of the wheels width.
    a high positive offset means the rim center and spokes are further to the outside of the car.
    a high negative offset means the wheel is set further inside the car, giving a lip or "deep dish" look.
    a "0" offset would have the same distance from the outside to the mounting surface (the inside of the wheel, where the studs go thru) and from there to the inside of the rim.
    It has a lot to do with how the wheel looks and fits on your car. if the offset is too positive for your car, the tire will rub the strut or the inner part of the fender well. That is exactly what happened to you right now.
    If the offset is too high for your car, the wheels will stick out too far and rub the edge of the fenders. It dont look good either. Parang Pato.
    There's a ton of ways to make bigger, wider, negative offset wheels fit cars, seeing as how the desired look is normally to have the outer most part of the wheel at the edge of the widest part of the fender.
    Negative camber, fender rolling, stretched tires, widebody parts, over-fenders, etc. all can help fit big wheels in small spaces but those are too much job to do.
    Dec 2008
    Quote Originally Posted by 1D4LV View Post
    stock sya ng civic, 15" ang mags pero I doubt it na para sa ganung model talga yun, galing ata yon sa 2001 model, not sure though.
    Dalhin mo sa casa. Mas mahal pero mas sigurado. You can also bring it to SERVITEK, YOKOHAMA SERVICE CENTERS.
    Most of the replies here are correct. 185/65/R15 is way too large for your car.
    Also, check mo sa mags and size niya. Usually, naka embossed ang wheel size sa mags.
    ah ok... different offset yan bro.
    Dec 2008
    Quote Originally Posted by ChevyChaser View Post
    do you have any idea how much its gonna cost having it check or adjust sa mga servitek?
    Dec 2008
    pwede po ba mgkaiba iyong size ng both sa harapan at both sa likod? im on a tight budget e.
    May 2007
    Pwede, parang stagered na wheel, like BMW, Corvette, Porsche. Just dont mix the wheel brand.
    You could do it like this. Just and example....
    Front Wheel----- 14" wheel....185 /50/ 14
    Rear Wheel-------15" wheel....195/ 45/15
    The only downside on this is you cannot rotate the wheel.
    Dec 2008
    eto po kasi available
    Front Wheel----- 15" wheel....195 /50/ 15 (new)
    Rear Wheel-------15" wheel....185/ 65/15 (this is my existing tire)]
    is this okay guys?
    ok lang ba iba ung brand nung unahan sa brand nung likod? dami gastos.
    Last edited by wilnor; January 29th, 2009 at 11:40 AM. Reason: need to add something
    Aug 2004
    Just get a full set of 195/50s.
    Again, the tires are just way too tall for your car. The 2001 Civic has bigger wheelwells. If you can't spend up front buy a used set of tires with some good tread, but sooner or later, rubbing will eat the tires you've got on now, both front and rear.
    is this okay guys?
    im using 195/50/15 and matagtag yung ride niya. since ek yung oto, ill advise na take the 55 series na lang rather than the 50's. pagnaubos yung 50 series ko, for sure ill switch to 55's. opinion lang po...
    if i were you, i will just get cheap tires with the same size. magiiba ang handling and grip if you will use different sizes. in you case, get the 185/65/15. may mga murang brands naman if you are in short of cash. examples are Gajah Tunggal, Kelly, Federal.
    or kung talagang tikis, bili ka ng used quality second hand.
    Dec 2008
    i think i'll get the 195 /50/ 15 khit used na lang muna siguro, i have 185/65/15 can't use this kasi nga sumasayad sas fender,hehe,
    Dec 2008
    BTW pwde ba trade in lumang gulong? para d naman sayang ung 5 sets ko na gulong,
Problems with tires
