Results 1 to 8 of 8
    Apr 2011
    Help sa mga experts dyan... ilang beses ko na nadrain yung tubig ganun parin after byahe ko meron paring putik ang radiator ko... ano kaya problem.. need na yata palitan yung head gasket... magkano magpatopoverhaul??? pwede na ba 3k sa labor yan kase sabe ng mekaniko ko... TIA...
    Oct 2011
    baka kailangan i-flushing na yan radiator mo. puno na cguro ng rust dahil tubig ang inilagay kaya nag accumulate na ang putik.
    kung dumi lang talaga and walang leaks. pa lavramon mo lang.
    What is the color of the accumulated dirt? Have you tried using a radiator flushing additive?
    If the cylinder head gasket is leaking, you might need to change it ASAP.
    Oil and water should not mix inside the engine.
    Jan 2011
    Quote Originally Posted by lanceaj29 View Post
    open the radiator cap when it's still cold then smell it. if it the residue is oil like and it smells like oil, then chances are your head gasket is leaking.
    Apr 2011
    thanks sa inyong lahat.. kulay brown yung putik at mukhang oil yun kc nagrarainbow sa tubig... meron kayo idea kung magkano magpatopoverhaul at magkano yung head gasket??? TIA
    Jun 2010
    Pag galing ata sa deep well yung tubig na nilalagay mo mas magkakaroon ng build up and putik because the water is mineral rich. Try having your radiator "overhauled" and put Wilkins distilled water instead. If you still get the same muddy residue then it may be from other sources.
    Apr 2011
    update ko lang kayo mga ka-tsikoters regarding sa problem ko...
    napa lavramon ko na oto at na change oil na nad yet meron paring kulay putik what i mean is langis pala yun hindi putik.. nagbago kulay ng lputik sa radiator ko kase nga bagong change oil...
    Ngayon plano ko patingnan ang gasket ko kay doc abet of sta rosa laguna, honda expert...
    Update ko kayo kung ano findings nya... Thanks for Viewing...
Problem on my radiator me PUTIK!!!!
