Hahaha! May helicopter ba!
Oh! I love this.
Anyway, that indicator is the check engine warning. The lights supposed to come on for that lenght of time, if didnt come out after started then there is a problem, meaning there is something wrong in the engine. You must bring your car to honda shop to analyze the problem.
If the check bulb didn't come on you would have ECU problems.
About the noise on the clutch...theres accutally a mouse behind the clutch pedal of your car.... they like to squeak.
Okey.... so much that joke!
YOU WANT TO SOLVED THE PROBLEM! WD40 is only a temporary lube, and since after you spray some lube on the pivot point of the pedal and the squeak stopped, you figured the problem out. It (the pivot point of the pedal) needs to be cleaned and greased lubricate on the pedal bushing or quadrant cable mount.
Get a spray can of WHITE LITHIUM GREASE throw the WD-40 away now................The lithium grease is long lasting, and the factory recommends this on your door hinges, so its good for your paint too.......
