Results 1 to 8 of 8
    Jan 2009
    mga sir ask ko lang, ano ba engine code talaga ng ph16a engine? kasi pag search ako sa net ng engine codes walang ph16a eh (ex: d15b, d16cz etc).. gs2 ko lang mkita specs niya, bore & stoke compression etc.. and bka may contact poh kayo jan ng nagbebenta ng d15b na engine.. kano kaya gastos kasama kabit para sa 93 civic hatch? tnx..
    Jun 2008
    kuya actually we have the same problem nagulat kasi ako nkita ko yung accord ko ang model eh PH20.. wala rin ako mkita tungkol sa knyang specs..
    mern po ata sa banawe di ko lang sure pero ask mo rin po pero magiingat magsama ka po ng magaling tuming at magaling sa pandinig bout sa ugong ng makina..
    sensya po hnd specific mga sagot ko pero cgro nmn hnd mawawalan dun sa banawe
    Dec 2007
    Technically a PH16 is a locally produced D16. Not sure which version though.
    In a sense there is no real specific D16 "match" to a PH16 because it's its own beast. If you want to give a PH16 VTEC capability, you can theoretically just bolt on a D16 VTEC cylinder head.
    This modification works well with PH15s (which are locally produced D15s). PH15 block + D15B head = VTEC.
    HTHs
    Sep 2005
    fyi...PH16 = d16z6 SOHC non-Vtec
    Dec 2007
    Quote Originally Posted by macoih12 View Post
    The 1990s Accord engines are F-series SOHC units. I would assume the PH20 is an F20A. The 1998-2002 Accord carried F22A engines.
    Take note that they're different from the old F20B (not sure which Honda this was found in) and F20C/F22C engines of the S2000. Those were DOHC units - the only DOHC F-series engines, and they have nothing in common with the SOHC F-series units.
    Jan 2009
    thanks sa mga reply paps.. wala na yung ph16a engine ko ngaun eh, bye-bye na sya.. i swap into a d16a block d15b camshaft..
    Apr 2009
    Quote Originally Posted by awww View Post
    bitin ba talaga ang ph16a sa hatch? diba 1.2 nga lang stock nun?
    Jan 2009
    depende sa gamit paps.. kung pang araw-araw nman ok na siguro ph16a vtec.. lakas na rin yun, magaan hatch eh..
PH16A engine code in japan??
