Results 1 to 10 of 12
- Nov 2009
- 1
November 13th, 2009 08:24 PM #1mga boss, tanong ko lang po kung swak ung cylinder head ng ph12 sa ph16?
- Apr 2009
- 1,902
November 14th, 2009 07:08 PM #2
November 14th, 2009 07:23 PM #3
ilovemyhonda..... one thing for sure.... downgrading the engine from ph16 to ph12 is not a good idea.... i would recommend na lang to use a d15b ch to the ph16 block.... as a mini me.... it will give you the function of vtec, 20 valves lobes and fuel efficinecy if the ecu (computer box) to be used is well tuned... one more is magpapalit ka din pala ng ecu from p27 to p08...
*isa1023.... fyi its not because it say ph12 it has 12vlaves sir.... ph12 means thre engine has a displacement of 1200c/cm or 1195c/cm and ph16 has displacement of 1600c/cm or 1595c/cm....
- Apr 2009
- 1,902
- Apr 2009
- 1,902
November 14th, 2009 09:16 PM #5Mr jemm01, hehe oo nga no sinearch ko din. 4 valves per cylinder nga yung d12 engine
^^Up... much better use internals from D engines with higher or at least equal capability as with the ph16 engine...
November 15th, 2009 02:48 AM #6
- Nov 2008
- 13
June 20th, 2010 11:51 PM #7mga sir, can ph12 engine modify, alter or enhance to gain extra horsepower? if yes, what do i need and where can i buy one.
- Nov 2008
- 13
June 21st, 2010 12:01 AM #8mga sir, can ph12 engine modify, alter or enhance to gain extra horsepower? if yes, what do i need and where can i buy one.
June 21st, 2010 12:12 AM #9
palitan mo nalang b16 or 18 if you want mre power..honestly ph12 is designed to be economical..not a performer.
Certified MB Addict
- Apr 2007
- 2,284
June 21st, 2010 12:43 AM #10
Since yung spare tire nasa labas ng sasakyan. Ano tawag dun sa lock na nilalagay sa spare tire para...
