Results 1 to 5 of 5
    Oct 2009
    HELP MGA KUYA KUYA PWEDE BANG LAGYAN NG LSD CLUTCH AND PH12 ENGINE? kupad kasi eh =))
    TIA PO SA ANSWERS
    LSD? Limited slip differential yan ah.
    Plus an upgraded clutch won't yield you power gains. Yes, it'll make the transfer of power more efficient, but if the source (that being the ph12 engine) is already weak to begin with, then there's no point. Waste of money.
    Spend it something else, like a new engine, if you're after speed and power.
    Feb 2009
    palit ka na lang ng d15,d16 or mag B series ka na lng.... tama si sir ssaloon, sayang money.. hehehehehe.....
    Aug 2004
    You can get an LSD off a JDM D15B transmission... but it ain't gonna do you much good.
    An LSD really won't matter much with the power of the 1.2 liter engine... it'll only become active if your inside front tire is spinning in a corner, when you have more power than grip, or when you're doing a 5000+ rpm drag launch and your tires can't control the power you're putting down.
    Of course, without the "power" part, there's really no need for an LSD... unless you're going rallying in the dirt... and even then, your typical 1.2 liter isn't going to overpower the tires too much on dirt (heck, I've raced non-LSD equipped 1.6s in the dirt with no problem).
    Just get a full JDM D15B swap... with the LSD. You'll be infinitely happier.
    Apr 2009
    Quote Originally Posted by greenwarrior View Post
    Up^^^
    Really few jdm d15b's came with LSD, so you'll be lucky enough if you find one...
    Good luck
Ph12 engine pwede ba lagyan ng lsd
