mga master san po ba pwede magpagawa nung goma sa gilid ng pinto and pati yung sa ibabaw? pag malakas ang ulan pumapasok na yung tubig sa loob. saka san pong shop ok gumawa ng power window. maraming salamat po. honda lxi po auto ko
same problem here. ung goma sa gilid ng pinto e di na masyado dikit sa body kaya pumapasok tubig pag lakas ng ulan. help us guys. san ba mura pagawa toh? tnx..![]()
Not sure if I have the same issue w/my car!
Water build up on driver's side flooring below foot rest.
I've already had whole flooring(front to rear) sealed then painted w/rust proofing thinking that water is coming from under chassis going in the car. I also replaced the under carpet foam/insulator, Main cause of foul odor in car!
Its still wet after Typhoon Juan! Is it possible that water is coming in from rubber seals of door cause mine have cuts(driver side only) or from the compartment under the wiper(I'm not sure what this part is called) going down to the flooring.
Have anybody had this experience on their cars?
Please help!![]()
