Results 1 to 7 of 7
- Jun 2009
- 44
November 1st, 2009 10:10 AM #1Mga sir,
Good day
Ano kaya gagawin ko,kase pag nag gagas ako then bigla kong binitawan while running parang napipigil yung pag takbo, hindi sya gradual kung magmenor tapos while at idle naman pag nag gas ako medyo delayed ng ilang seconds mag bigay ng gas. ;while at idle pa rin,pag binitawan ko yung gas pedal nanginginig yung car na parang nawawalan ng power habang bumababa yung RPM niya tapos biglang babalik sa normal idling(lalo na pag nakaload yung aircon,ano po kaya ang problema nito mga boss??
Pahelp naman
Thank you in advance..
November 1st, 2009 10:53 AM #2
What is your ride? If fuel injected have your throttle cleaned and serviced by a qualified mechanic. If (carburador) have it overhauled. Hope this helped.
- Jun 2009
- 44
- Mar 2007
- 44
November 3rd, 2009 11:33 AM #4try mo po i-pa tune up, there are a lot of factors to consider pag dating sa mga problem na ganyan. puwede pong oil pressure or sa timing lang ng engine. puwede rin pong my nka bara sa fuel line or ngloloko po ung fuel pump niyo. pwede rin pong hindi po siya gano na-warm up.
November 3rd, 2009 11:42 AM #5
A/T po ba? parang similar din sa LXi namin..while on neutral at idle pag tumapak sa gas parang hirap 'umakyat' ung rpm? at medyo napipigil ang pagtakbo pag binitawan gas pedal..
November 3rd, 2009 12:31 PM #6
Baka masama yung nabili na gasolina?... baka may halo ng tubig o marumi?
- Jun 2006
- 7
December 1st, 2009 02:07 AM #7having the same problem now...pa check ko tom.. here are some possible scenarios for this:
1. wala sa timing lang
2. need to clean the throttle
3. tune-up and replace spark plugs
try to update you guys kung alin dito ang naka solve...but older post na yung sa inyo so most likely na aayos na mga auto niyo.. hehe
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
