Results 1 to 11 of 11
    May 2009
    mga bro, everytime mataas RPM ko during arangkada or during rekta, merong parang kalansing akong nadidinig, pero kapag binitawan ko yung accelarator nawawala yung kalansing, ano kaya yun?
    note: my car is honda civic lxi '96
    Oct 2009
    it might be sa exhaust system. possible sa resonator.
    May 2009
    Quote Originally Posted by TheNaughtyCrew View Post
    tope yan... kalansing na parang mga coins ba? tunog sa under the hood?
    kapag duon ang source ng sounds
    Tumo-tope makina mo, mean wala sa timing...
    try to change your fuel make it 95 octane grade...kapag hindi nakuha have your timing position and distributor position checked by trusted mechanic
    May 2009
    *Josmic
    I am currently using Petron XCS with my civic, dati naka ford lynx ako using unleaded, nagkaron din siya ng kalansing, then after magpalit ako ng XCS nawala, pero this time I am using XCS pero meron pa rin, so malamang sa timing na yun?
    *Josmic
    Either adjust your timing or use a gasoline with higher octane rating.
    May 2009
    *ghost
    I will try Petron Blaze 100% Octane, pero uubusin ko muna laman ng fuel tank ko para sure na maramdaman ko effect, I will update the thread once ma-try ko na, thanks!
    *Josmic
    If after using the new Blaze with a 100 octane rating and the problem still persists, then a more thorough examination of the engine by a competent mechanic is highly recommended.
    May 2009
    *civicvti
    will do that after, thanks.
    May 2009
    Mga bro, I tried Blaze 100, nawala yung kalansing, then nung bumalik ako sa XCS, bumalik din kalansing, confirm na sa gas na talaga 'to!
    Problema mahal ang Blaze, nasa around P5.00 per liter ang difference from XCS!
    Next na susubukan ko is the Shell V-Power, pero until now wala pa ring supply!
Kalansing at High RPM
