Results 1 to 9 of 9
- Nov 2010
- 12
February 13th, 2011 07:06 PM #1paano po ba yun sinasabi na 1.6, 1.3, 1.8, 2.0 etc? sabi po fuel consumption, paano po ba yun? thanks!
- Oct 2010
- 240
February 13th, 2011 07:51 PM #3well explained wiki...
so the bigger the displacement, the bigger the FC!
- May 2010
- 87
February 13th, 2011 07:55 PM #4
- Oct 2010
- 240
February 13th, 2011 08:15 PM #5
- Dec 2010
- 87
February 14th, 2011 02:19 AM #7If 4 cyl to 4 cyl di gaano makikita ang diff ng FC pero if 6cyl vs 4cyl mas matipid ang 6 if pareho ang Gross Vehicle Weight, Gross axle weight at Driving habbits. also 6cyl vs 8cyl if same ang Gross Vehicle Weight at Gross axle weight. and if engine induction system equip with dual resonance, malaking factor yon sa driveability. a classic example is MBENZ 124 body with 2.3 ltr engine (102 4cyl ) consumed more fuel than 124 body with 2.6 ltr engine ( 103 6cyl ) if pareho ang driving pattern ng both drivers.
- Oct 2010
- 240
February 14th, 2011 09:03 PM #8strictly on displacement and dropping all other factors mentioned, which will have higher FC?
- Jun 2008
- 1,741
February 14th, 2011 09:19 PM #9Assuming that the bigger displacement engine has more power output than the smaller one then running them at the same rpm like say in the shop trial with out load (like at idle speed when the car is not moving) syempre ang consumo ng mas malaking makina ay mas mataas keysa sa maliit. Bigger displacement & power consume more fuel.
Daming issue ng SU7:grin:
Xiaomi E-Car
