Page 3 of 3 FirstFirst 123
Results 41 to 60 of 84
    ^^^ When was the last time you change the water pump and timing belt?
    Nov 2016
    I'm not sure when it was last changed. Kakabili ko lang nung kotse 3 months ago.
    I could try contacting the seller.
    Or should I go ahead and have them replaced?
    Quote Originally Posted by neoson9999 View Post
    Timing belt replacement is every 80k km. With Honda engines, you replace the water pump together with the timing belt.
    Di sinabi ng previous owner na nag overheat na yung kotse before? Dapat sinabi nya reason for taking off the thermostat.
    is the coolant being sucked in from the radiator fill port?
    Nov 2016
    Hindi niya sinabi
    Mga magkano kaya yung damage na aabutin kung papalitan ko yung timing belt and water pump?
    Doesn't look like it.
    Jun 2004
    Hindi niya sinabi
    Radiator/Aircon fans working properly? If weak consider replacing the fan motor.
    Given the vehicle age consider replacing the radiator cap, upper and lower radiator hoses.
    Using coolant mixture or distilled water only?
    Timing belt kit outside CASA around 3-4k cguro, labor mga 1-2k.
    Nov 2016
    Hindi ko na pala na replyan to haha
    Na solutionan na yung overheating problem ko. Binleed ko yung radiator ng todo todo tapos pinalitan ko na rin yung rad cap at rad fan.
    Ayun, di na siya nag ooverheat basta mag drive ako reasonably.
    Thanks guys
    Thanks guys
    so, which among the three, was the culprit?
    in my opinion, even if one drove un-reasonably, it should not overheat.
Over heat
