Results 1 to 12 of 12
    Aug 2009
    Mga Sir,
    need help po, may thread na ako dito kasi gawa ulit ako bago.
    Problem: May leak nanaman po yung enine ko sa ilalim.
    1. Yung isang leak banda dun sa may cover ng Timing Belt area, dun pumapatak yung oil eh kasi sinilip ko sa ilalim (patak patak lang naman). Kaso nakakairita at nakakadumi sa garahe.
    2. yung isa naman dun banda sa gitna, bandang Oil Pan area (patak patak lang naman) not sure kung san ciah galing kasi sinilip ko eh di ko ma trace. San po kaya ciah nag leak?.
    History: Last August, may leak na po yung sa may timing belt area, then I decided na to replace the Timing Belt kasi palitin. So nagpalit ako ng timing belt, water pump and tensioner bearing. I also replaced the Crankshaft Oil Seal, Camshaft Oils Seal, valve Cover Gasket at Oil Pan Gasket. After nun, wala ng leak, then after a month, ayun...bumalik nanaman. Yung O-Ring sa oil pump hindi pinalitan ng mechanic.
    Tingin nio mga sir, anu po kaya problem nito? San po ba located yung Oil Pump ng Honda City 98 model?
    Malolos, Bulacan area po ako...baka may alam po kaya na expert sa ganitong problem.
    nakuha ko lang po sa forum yan, I think we have the same problem....dun galing yung patak ng oil eh. Sabi dun sa forum eh sa crankshaft oild seal daw.....odd thing is kakapalit ko lang nun e. Yun po bang OIL PUMP is same as OIL DISTRIBUTOR? may possibility po bah na dun sa O-ring galing yung leak???
    May 2007
    The oil pump is usually located right next to the oil filter.
    So all gasket are new, make sure all seal are seated properly and all bolts are not lose or too tight. Always use a torque whenever thighten those bolts no hunky funky style.
    Iyong mga nabibili nating mga oil pan gasket na replacement ay hindi magandang klase madaling tumigas kaya nagkakaroon ng leak . Nangyari na rin ito . Original na oil pan gasket ba kinabit mo at mga oil seal.
    Aug 2009
    Quote Originally Posted by speed unlimited View Post
    bro, lahat nung gasket ko and oil seal eh sa HONDA ko binili, mas mura kasi kesa sa labas eh.....di ko talaga alam kung ano dapat kong gawin dito...
    anymore advise mga sir?
    Aug 2009
    sir,
    anymore advise kung anu dapat gawin ko dito?
    as i've said po, kaka replace ko lang ng mga sumusunod last August:
    1. Timing Belt
    2. Water Pump
    3. Crankshaft Oils Seal
    4. Camshaft Oil Seal
    5. Oil Pan Gasket
    6. Valve Cover Gasket
    All honda po yung mga yan, sa Honda ko po binili lahat.
    Yung leak po dun nanggaling ung tulo sa cover ng Timing Belt (konti lang naman kaso nakakairita). Pati dun sa bandang left side ng engine meron konti di, I think near siya sa Oil Filter.
    Di naman po ganung kalakas yung leak pero of course, nakakainis lang at nakakadumi ng garahe. Gusto ko po sana once and for all maayos ito.
    Mas maganda kung sa Honda mo binili . Hindi kaya doon sa ilalim ng distributor mo nanggagaling ang leak halos pinalitan mo na lahat ng gasket at oil seal sa makina .
    Baka sa luma mo pang leak yan. Pa Engine Wash mo then kapag malinis na try driving after ilang days check mo ulet kung tumutulo then kung meron pa means may leak pa. Nangyari na sa akin yan before and na-verify ko kung leak nga ba or lumang langis na di nalinisan lang.
    bro.. napaayos mo na yang leak ng engine mo... meron ako kc kilala mekaniko na puro honda lang ang ginagawa nila.. siya rin ang gagawa ng honda city ko.. ito ym ID ko.. eds1910... buzz mo lng ako
Oil Leaks...again!!!
